vincemiller
Oct 20, 2016Aspirant
Firmware update V1.3.0.12
Anybody else get this tonight? I just checked for an update and V1.3.0.12 showed up and downloaded. Up and running, just not sure what it did. Looks like the webpage isn't updated yet. 🤔
- Oct 20, 2016
If you click on the V1.3.0.12 link in the Firmware Update page it shows a nifty popup with the changes:
Current Version: V1.2.0.6 New Version: V1.3.0.12 Release Notes:
[New or Enhancement Feature] Supports Canada and China wireless regions.
[New or Enhancement Feature] Optimizes the 5 GHz backhaul RTS threshold to improve the wireless performance.
[New or Enhancement Feature] Supports OpenVPN.
[Bug Fixed] Fixes the issue in which some devices display as "unknown" in the Attached Devices page. [Bug Fixed] [Security Fix]Fixes the issue in which IPV6 port 80 and 443 closes by default.
[Bug Fixed] Fixes the GUI language for China.
[Bug Fixed] Fix the issue in which wireless devices display as “wired” in the Attached Devices page.
[Bug Fixed] Corrects the DNS configure issue when Parental Controls is enabled.
[Bug Fixed] Fixes the firmware auto update fail issue when multiple satellites are updated.
[Bug Fixed] Fixes the issue in which the incorrect number of connected devices are displayed.
rhester72
Oct 21, 2016Virtuoso
What the heck? So we can no longer see which devices are connected to the router versus the satellite? :P
Rodney
loomis1975
Oct 21, 2016Luminary
Looks like it. Have to log in to the satellite seperately now to look at its attached devices list.
- rhester72Oct 21, 2016Virtuoso
...where you can't define device names (can only be done on the router).
This is stupid! Why on earth would this UI change be made, unless it's to reduce complaints that devices aren't properly connecting/migrating to the appropriate AP (which is true)?
*sigh* Don't get me wrong, I love my Orbi setup. I've gone through Google OnHub and eero to get here. For my home, Orbi is *by far* the best solution - but damn, I hope they aren't going down the route of obfuscation versus actually fixing issues. We still can't see the quality of the backhaul link, for Chrissakes! :/
Rodney
