vincemiller
Oct 20, 2016Aspirant
Firmware update V1.3.0.12
Anybody else get this tonight? I just checked for an update and V1.3.0.12 showed up and downloaded. Up and running, just not sure what it did. Looks like the webpage isn't updated yet. 🤔
- Oct 20, 2016
If you click on the V1.3.0.12 link in the Firmware Update page it shows a nifty popup with the changes:
Current Version: V1.2.0.6 New Version: V1.3.0.12 Release Notes:
[New or Enhancement Feature] Supports Canada and China wireless regions.
[New or Enhancement Feature] Optimizes the 5 GHz backhaul RTS threshold to improve the wireless performance.
[New or Enhancement Feature] Supports OpenVPN.
[Bug Fixed] Fixes the issue in which some devices display as "unknown" in the Attached Devices page. [Bug Fixed] [Security Fix]Fixes the issue in which IPV6 port 80 and 443 closes by default.
[Bug Fixed] Fixes the GUI language for China.
[Bug Fixed] Fix the issue in which wireless devices display as “wired” in the Attached Devices page.
[Bug Fixed] Corrects the DNS configure issue when Parental Controls is enabled.
[Bug Fixed] Fixes the firmware auto update fail issue when multiple satellites are updated.
[Bug Fixed] Fixes the issue in which the incorrect number of connected devices are displayed.
AniDutta
Oct 21, 2016Apprentice
I think this was a deliberate implementation to stop people from raising questions on how/which router/satellite devices connect to.
rhester72
Oct 21, 2016Virtuoso
From the debug page, you can check "Enable advanced view of Attached Devices page", which will bring the old (split router/satellite) view back.
It also now indicates which radio (2.4GHz or 5GHz) the device is connected to, which is nice!
Not sure why on earth this is buried on a hidden debug page - why not put it under advanced/administration?
Rodney
