vincemiller
Oct 20, 2016Aspirant
Firmware update V1.3.0.12
Anybody else get this tonight? I just checked for an update and V1.3.0.12 showed up and downloaded. Up and running, just not sure what it did. Looks like the webpage isn't updated yet. 🤔
- Oct 20, 2016
If you click on the V1.3.0.12 link in the Firmware Update page it shows a nifty popup with the changes:
Current Version: V1.2.0.6 New Version: V1.3.0.12 Release Notes:
[New or Enhancement Feature] Supports Canada and China wireless regions.
[New or Enhancement Feature] Optimizes the 5 GHz backhaul RTS threshold to improve the wireless performance.
[New or Enhancement Feature] Supports OpenVPN.
[Bug Fixed] Fixes the issue in which some devices display as "unknown" in the Attached Devices page. [Bug Fixed] [Security Fix]Fixes the issue in which IPV6 port 80 and 443 closes by default.
[Bug Fixed] Fixes the GUI language for China.
[Bug Fixed] Fix the issue in which wireless devices display as “wired” in the Attached Devices page.
[Bug Fixed] Corrects the DNS configure issue when Parental Controls is enabled.
[Bug Fixed] Fixes the firmware auto update fail issue when multiple satellites are updated.
[Bug Fixed] Fixes the issue in which the incorrect number of connected devices are displayed.
rhester72
Oct 21, 2016Virtuoso
From the debug page, you can check "Enable advanced view of Attached Devices page", which will bring the old (split router/satellite) view back.
It also now indicates which radio (2.4GHz or 5GHz) the device is connected to, which is nice!
Not sure why on earth this is buried on a hidden debug page - why not put it under advanced/administration?
Rodney
peteytesting
Oct 21, 2016Hero
rhester72 wrote:From the debug page, you can check "Enable advanced view of Attached Devices page", which will bring the old (split router/satellite) view back.
Rodney
totally agree and the same for telnet
im not sure why they chose to hide ether at this stage as it makes no sense and just makes ppl angry and more frustrated than they already are
