esb2b's avatar
esb2b
Guide
Dec 27, 2020
Firmware Updates
I got an email to update my firmware, currently I am running V2.5.2.4, so whan I go to the advanced tab to check for updates it tells me I am up to date with V2.5.2.4, but if I navigate to manual updates I see I have missed one completely - why wont the search for updates function work anymore? thx
  • CrimpOn's avatar
    CrimpOn
    Can you copy and past the contents of this email?
    There have been a number of posts recently reporting this, and since I never have received one (ever, in 4 years of having my Orbi), I'd like to see what one looks like.
    Thanks
    p.s. There are a lot of posts recently about the behavior of Orbi firmware updates and how they relate to the firmware release that is on the Orbi.  See this thread, for example:
    https://community.netgear.com/t5/Orbi/Orbi-RBR50-Router-Firmware-Version-V2-7-2-102/m-p/2027821#M109584
    • esb2b's avatar
      esb2b
      Guide
      I saw a thread where it updat4ed overnight - I wpudlnt mind that if mine auto updated, but usually you log into netgear and go to the advanced tab and update there - the advanced tab doesnt even show the latest updates anymore - this isnt normal
      • vajim's avatar
        vajim
        Master
        do you know why you want to update?  Problems with your system?
    There's your answer
    • esb2b's avatar
      esb2b
      Guide
      No. The manual way shows 2.7 now and there were a few prior - 2.6 etc that I never saw. The Netgear site is not showing accurate data.
      • CrimpOn's avatar
        CrimpOn
        If you slog through that post about firmware v2.7.2.102, there are assertions that Netgear "appears" to have created multiple firmware versions which apply to different customers, depending on whether they are in the US and whether they have subscribed to Parental Controls.  My Orbi (in the US) is on 2.5.1.16 and Firmware Update tells me that 2.5.2.4 is available.  It makes no mention of 2.6.1.40 or 2.7.1.60 (US Only).  (In the software business, different versions are often called "forks".)
        As far as I can tell, Netgear is totally silent about what all this means.  With my other systems, I update software frequently.  With Orbi, I read with great interest the stories that people post after they choose to update (or an update happens to them).  In the past two years, there have been many firmware updates that caused massive problems for some users.  Some firmware updates have been "pulled."
        What I would dearly love is a clear statment from Netgear, such as "Versions of firmware prior to vx.x.x.x are vulnerable to these specific security threats (with a list) and customers are encouraged to update to version x.x.x.x"  Other companies do this all the time.
