rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Doug-48051
Jul 11, 2017Luminary
I completed online update of 1.12.0.18
But now I cant tell if my SAT updated.?
Do I need to do a manual update on SAT? It shows CURRENT Version, but Update Failed ERROR
- Doug-48051Jul 11, 2017Luminary
Support helped correct my FW update error... I did a manual update for the SAT to get the information from the upate page to match.
3 hours on new FW 1.12.0.18 - Solid number on all devices thus far.... Comcast ...fingers crossed :)
Happy DAY.... Same speeds at SAT
- jleecloak1Jul 11, 2017Apprentice
I hope this is the fix needed. I'm and going to end my eBay auction early on my Orbi and give it one last shot. This is the first time I have seen support email a firmware and post it to the message boards with such confidence.
- LanderxJul 15, 2017Apprentice
How can I get that Update Failed message to go away? I updated to the latest firmware.
Status Router RBR50 RBR50 V1.12.0.18 No new firmware version available. Satellite RBS50 RBS50 V1.12.0.18 Update failed - captain_phaserJul 15, 2017Apprentice
I had the same thing happen. What I did was first downloaded 1.12.0.18 firmware and updated both router and satellite manually even though it was already the same version. It still said update failed on the satellite, so I turned both units off, and then turned the router on, followed by the satellite. I Manually pressed sync on the router 1st and then the satellite and after they synced, the error was gone. I think the power cycle followed by the re-sync did the trick, but you could try the whole procedure I did if that doesn't work.
