rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Doug-48051
Jul 11, 2017Luminary
Does NETGEAR provide a list of bug fixes or enhancements file with their updates?
Doug-48051
I found where release notes are posted. 1.12.0.18 arent there yet... I will check back later.
- martyfpJul 11, 2017Luminary
Bug Fixes:
Download Link:
- jcalex22Jul 16, 2017Star
FYI,
With firmware V1.12.0.18 when Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices is enabled, my satellite disconnects and will not work at all. I've tried a factory reset on BOTH the Orbi router and satellite. It says the sat is detected, but will not activate after the setup procedure.
Turn this setting off and all is well again. That was four hours of my life that I won't get back again. Needs a revised firmware version.
- jleecloak1Jul 16, 2017Apprentice
jcalex22 wrote:FYI,
Don't you hate that? The troubleshooting with this router can take way longer than it should sometimes.
- sjobAug 03, 2017Guide
V1.12.0.18 has major problems. My RBR50 system disconnects my Wifi devices constantly. Satellite is blinking white unless I sync it manually. After a while it starts blinking white again.
- LanderxAug 05, 2017Apprentice
Why isn't this latest firmware available to be downloaded in the download section?
- RogerSCAug 05, 2017Virtuoso
Landerx wrote:Why isn't this latest firmware available to be downloaded in the download section?
The latest firmware is available on the download section, at least for the RBK50, anyways. And it has been working well for me, aside from not being able to disable the 2.4GHz. wireless. Although I wouldn't be using it if I could go to the previous release and use of that without having the Orbi flash back to the latest version of firmware when it feels like it :-).
Here's the URL that I use for support download for the RBK50:
https://www.netgear.com/support/product/RBK50?cid=wmt_netgear_organic#
