rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
AmitR
Jul 11, 2017NETGEAR Employee Retired
Yes, indeed, late last night, we pushed out OrbiOS 1.12.0.18 in response to reports of wireless disconnects, including those with Nestcam / Dropcam, Macbook Pro that have been affecting some users. Over the last few weeks, we’ve taken concrete steps to investigate & address them, including running a comprehensive beta program. Over the next few days, your Orbi will automatically download this firmware and upgrade itself. If you want to manually upgrade, feel free to perform a manual upgrade through orbilogin.net).
We’d like to thank our beta users and Community for helping us through this, and those of you running the beta release (1.11.0.8 or earlier versions of 1.12) should upgrade to this new release.
In addition, in this release, for those customers who have an Orbi with a USB port (RBK50 or RBK53), we’re enabling the USB ports for uses like attaching a printer. This has been a widely requested feature request from the community and we’re happy to deliver.
Orbi Product Team
