rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
captain_phaser
Jul 11, 2017Apprentice
So it appears that the ability to disable either 2.4GHz or 5GHz has been removed even though it was already available. In my situation, the 5GHz band outperforms the 2.4GHz everywhere on my property so I disabled the 2.4GHz band. It was causing my devices to be "stuck" on 2.4 channels half the time due to the forced band steering. Even with this new update I am getting the same behavior. This is quite upsetting as now I have to connect and disconnect several times before my devices are on 5GHz. I have tried waiting, and it does not switch correctly 50% of the time. By all means, keep both bands enabled by default. But give back the option to disable them in the advanced settings.
- StkasmJul 11, 2017Apprentice
captain_phaser So, I had a similiar problem before, back when I had only one router and one satelite. What you can do is drop TX power for 2.4Ghz to like 25% on Orbi, which will level it up with 5Ghz band. Clients should stop switching to it.
- st_shawJul 11, 2017Master
Stkasm wrote:What you can do is drop TX power for 2.4Ghz to like 25% on Orbi, which will level it up with 5Ghz band. Clients should stop switching to it.
Have you tried that on the new firmware?
I did not. When I left for work this morning, my system was still running 1.11. I plan to update it this evening.
- JMU1998Jul 11, 2017Luminary
I still don't see the logic to take away the option to disable 2.4GHz those who want both on can, those who don't have the option. In my environment speeds and range were fine using only 5GHz radio. I have absolutely no need for 2.4Ghz. Now even take away the ability to lower the radio power on top of taking away the option to disable? we all have different needs and environments one shoe does not fit all.
- JAYSONEJul 11, 2017Star
Can anyone help me!?!
My orbi system was previously auto updated to V1.12.0.20. Today it is now on this version and now I have the following issues.
The satellites are NOT showing up under "Attached Devices" as satellites...they do however, show up under connected devices. Logging into their respective status pages by way of their listed ip, I see that both of my satellites are updated to this latest version and the wireless AP are listed as OFF, 2.4ghz & 5ghz are listed as disabled.
My router is acting fine and the satellites are connected to it...how do I enable the wifi on the satellites so my devices can connect to them?
Please advise, this is driving me crazy! Thanks in advance.
- marshymallowJul 11, 2017ApprenticeIt happened to me initially after the FW update. Power off and On the Sat and wait awhile. The main router should set things right thereafter.
