rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Retired_Member
Jul 11, 2017I was hopeful this update would show me the following under attached devices:
1. Which band (2.4 or 5.0GHz) a wireless device is attached to. How about just replace the term Wireless in that column with 2.4GHz or 5.0GHz?)
2. which unit (base or satellite) an attached device is linked with
Does anyone know how I can determine from the router interface what band a given devices is using at any given point in time?
martyfp
Jul 12, 2017Luminary
note : you can enable the feature to display the band that each attached devices is connected though. Follow the instructions here :
https://community.netgear.com/t5/Orbi/hidden-features/td-p/1149584
It does not tell you which unit it is attached to though,
- dowopJul 12, 2017Tutor
Link will not work for me.
I can see the satelite on the router log in & the adress was changed. Tried logging into the satellie with new address & no joy.
