rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
esiebert7625
Jul 12, 2017Star
yeah that's what I was thinking, downloads.netgear.com is the download URL it appears from their download link on their website. Talking to support right now about it.
tolive
Jul 12, 2017Guide
The problem is, is there any previous firmware version that does not have the Wi-Fi disconnecting issue?
- esiebert7625Jul 12, 2017Star
every version has been solid for me up until this one, their phone support is pretty crappy, some Indian lady wants me to enable Implicit Beamforming and all my disconnect problems will magically go away supposedly.
She also claims if you do a manual firmware update it will disable any future automatic updates, not sure that I believe that.
- martyfpJul 12, 2017Luminary
I'm running full router mode and so far things have been stable on the new FW. (was dropping regularly before)
One other thing that I did - not sure if it is significant - but after the update I forced the iphones to forget the SSID then rejoin again. NO idea if that helped or not.
At this point I am happy - however, the kids are now home and hammering the network. I am holding my breath
So oddly enough after enabling Implicit Beamforming both my IOS and Android devices that were disconnecting after about a minute are stable now. My easy test for this is to load Clash of Clans which is sensitive to bad connections when you get the dreaded in-game wifi symbol. After the update they would both consistently disconnect after about a minute, with Implicit Beamforming enabled so far has been OK with no disconnects. I had never had an issue before this update and IB was always disabled by default. Does this mean Implicit Beamforming is required with all the disconnect issues that they fixed in this release.
