rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
esiebert7625
Jul 12, 2017Star
I spoke too soon, my Galaxy S7 Edge still is disconnecting after the update. I just downgraded back to 1.11.0.20. Way to go Netgear and ruin my perfectly functioning wifi that has worked fine for 8 months with a crappy update like this.
JMU1998
Jul 12, 2017Luminary
Now I have a 2.4GHz radio on for which I have zero use contributing to the interference in an already congested neighborhood and NO way to turn it off or turn the signal down!! How nice to have a 2.4GHz radio with no assigned SSID running for which I have no use brilliant design! Why Netgear why did you take away the ability to turn off or reduced power on 2.4GHz?
- BStingerJul 17, 2017Tutor
JMU1998 wrote:Now I have a 2.4GHz radio on for which I have zero use contributing to the interference in an already congested neighborhood and NO way to turn it off or turn the signal down!! How nice to have a 2.4GHz radio with no assigned SSID running for which I have no use brilliant design! Why Netgear why did you take away the ability to turn off or reduced power on 2.4GHz?
I agree completely! I also have no use for the 2.4GHz radio.
Why is Netgear taking away features?? Leave the advanced options in the system for advanced users!!
