rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
DarrellRiffe
Jul 13, 2017Apprentice
Yeah - I'm seeing the same thing. Obvious coding error...
la79 wrote:
After updating to this firmware I noticed that all my devices are now listed as "wired" in the Orbi App and the Network Map in theGenie App. Even though they are wireless devices.
They are showing as wireless when I login in locally to the router as they should be. This happening to anyone else?
JMU1998
Jul 14, 2017Luminary
Now that we have had conformation from many people is Netgear going to acknowledge or take a note of this? Any moderator want to confirm this has been taken up to Engineering?
- OrbiPhilipJul 14, 2017Luminary
24 hour performance indficators for v1.12.0.8. As you can see, Satellite performance is terrible relative to the router. And my load on the satellite is trivial 99% of the time. Idle printer, idle Tivo, my phone getting periodic email updates.
And there is definitely a problem with the "Tx/RX B/s" fields. It appears to be an incrementing counter, not a rate indicator as labeled. Assuming the values are accurate, I'm also curious why the ratio is so skewed.- Killou92Jul 14, 2017Tutor
This firmware is really bad... First I lost my satellite and I had to reset both devices to fix the issue, then I realized that my Galaxy S8 was dropping internet every 2 minutes (I did forgot network etc).
I went back to the previous firmware and I'm having no issue 1.11.0.20.
Thanks
- Retired_MemberJul 14, 2017
For me and my 90+ devices, it's back to rock solid fixing the issues 1.11.x introduced.
- TheEtherJul 14, 2017Guru
OrbiPhilip, the Tx B/s value for WLAN Backhaul is bogus. In computer programming, 4294967295 represents the largest value of 32 bit unsigned integer. It can also represent the value -1 for a 32 bit signed integer. There is clearly a bug in the firmware.
