rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
ArtLee
Jul 13, 2017Apprentice
la79 wrote:
After updating to this firmware I noticed that all my devices are now listed as "wired" in the Orbi App and the Network Map in theGenie App. Even though they are wireless devices.
They are showing as wireless when I login in locally to the router as they should be. This happening to anyone else?
Yes, And, all show 100% strength in the Genie App which makes sense if they're wired, but they're not wired.
raven_au
Jul 14, 2017Virtuoso
ArtLee wrote:
They are showing as wireless when I login in locally to the router as they should be. This happening to anyone else?Yes, And, all show 100% strength in the Genie App which makes sense if they're wired, but they're not wired.
I see the same behaviour, all WIRED in the Orbi app and all 100% signal strength in the Genie app.
Ian
