rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
dsc_dewain
Jul 15, 2017Guide
**UPDATE RESOLVED **
Turns out when I hit the status page on the satellite, the firmware update never took affect originally.
The satellite was still on v1.11.0.20
I manually updated the firmware, now I see it as an attached device, and also on the firmware update page.
With V1.12.0.18 My satellite doesn't show up anymore in the attached devices, etc. I've powered it off and stuff, but doesn't show up. Anyone else having this issue?
MacrossMike
Jul 15, 2017Apprentice
Yes, I've been having the same issue with 1.12.0.18.
Something about it doesn't seem to agree with any model of Orbi satellite, and causes a variety of symptoms like:
- Orbi satellites showing up as WiFi clients instead of satellites under "Attached Devices".
- Orbi satellites not having their non-backhaul WiFi switched on once fully booted.
- Very slow ping between Orbi satellites and the router, and between connected devices and the net.
- Firmware update checker returning "Update failed" status on the satellite (possibly a symptom of the ping issue).
