rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
DUSTOFF2
Jul 15, 2017Guide
Here is what I can say, all connectuons are showing wired adter update. Prior to update I was getting full or close to my 175 meg down and 23 to 25 meg up. After update that has,been cut to about 80 to 90 meg if going of the sattelite. The up always remains the same at 23 to 25 meg.
I unplugged the Sat so it just go bandwidth from router. The router is in basement and Sat is on main floor. The speed I got was around 60 to 65 meg down and 23 up. When I go downstairs,with speed test I get the 175. Something not going on well with the sat.....they both have updated firware... if this is not corrected soon they going back I want my 175 back from sattelite
Stkasm
Jul 15, 2017Apprentice
I have it in AP mode, web ui is showing Wired / Wireless correctly. I also tested both satellites, I can get 400-500Mbps from each of them.
