rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
jleecloak1
Jul 16, 2017Apprentice
jcalex22 wrote:FYI,
With firmware V1.12.0.18 when Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices is enabled, my satellite disconnects and will not work at all. I've tried a factory reset on BOTH the Orbi router and satellite. It says the sat is detected, but will not activate after the setup procedure.
Turn this setting off and all is well again. That was four hours of my life that I won't get back again. Needs a revised firmware version.
Don't you hate that? The troubleshooting with this router can take way longer than it should sometimes.
Seattleite
Jul 17, 2017Guide
Just to add to the signal (and hopefully not the noise) -
I do not have beam-forming nor mu-mimo enabled, and yet I have also lost connectivity to my 2 satellites. They show up as connected devices, but not as satellites. I'll admit I haven't been actively checking out firmware revisions, but would anyone like to guess when an updated and fixed firmware might be released? I can wait a day or two, but if it's going to be weeks, I think I'll have to revert to a previous firmware and disable the auto-updates...
Thanks in advance....
- ArtLeeJul 17, 2017Apprentice
Seattleite wrote:Just to add to the signal (and hopefully not the noise) -
Can you log in to the two satellites? If so, can you tell if other devices are connected to the satellites. If you log in to the router, you should be able to see the IP address for each satellite. Then try logging in to each one via that IP address with the same credentials for the router.
- SeattleiteJul 17, 2017Guide
I just logged in to both satellites. From the status page image, it appears that both the 2.4GHz and 5Ghz are (Disabled), with Wireless AP off, and none too surprisingly, no devices are connected to either of them. They are both running with firmware V1.12.0.18.
Seattleite wrote:I just logged in to both satellites. From the status page image, it appears that both the 2.4GHz and 5Ghz are (Disabled), with Wireless AP off, and none too surprisingly, no devices are connected to either of them. They are both running with firmware V1.12.0.18.
And, your modem/router is back in Bridge mode?
I'm not an expert, but have -some- experience and I'd suggest modem/router be left in bridge mode, with wifi turned off. With two routers with wifi signals, things can work against each other, both routing-wise and radio-wise.
