rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Seattleite
Jul 17, 2017Guide
I just logged in to both satellites. From the status page image, it appears that both the 2.4GHz and 5Ghz are (Disabled), with Wireless AP off, and none too surprisingly, no devices are connected to either of them. They are both running with firmware V1.12.0.18.
ArtLee
Jul 17, 2017Apprentice
Seattleite wrote:I just logged in to both satellites. From the status page image, it appears that both the 2.4GHz and 5Ghz are (Disabled), with Wireless AP off, and none too surprisingly, no devices are connected to either of them. They are both running with firmware V1.12.0.18.
And, your modem/router is back in Bridge mode?
I'm not an expert, but have -some- experience and I'd suggest modem/router be left in bridge mode, with wifi turned off. With two routers with wifi signals, things can work against each other, both routing-wise and radio-wise.
- SeattleiteJul 17, 2017Guide
My modem is just a modem! There's no wifi router in there....
- ArtLeeJul 17, 2017Apprentice
Seattleite wrote:My modem is just a modem! There's no wifi router in there....
Okay. All Orbis on same fw version? No duplicate IP addresses visible in router login? I'm really puzzled, if you have rebooted the Orbis. Now, beyond my expertise. I'll watch this thread.
Yup, they're all on V1.12.0.18. It looks like there are other Orbi users with the same loss of satellites. When I get home, I'll do a manual update of the firmware just in case it was corrupted somehow....
Thanks for the tip on logging into the satellites directly!
- dpdurstJul 17, 2017Luminary
Mine ran about a day and then the following day in the afternoon the Sat dropped and was no longer connected. I could get to it via the IP, and had 2 devices connected to it but it didn't show up in the Router page at all.
Reset both router and satellite and then resync both back up and its been fine so far.
dpdurst wrote:Mine ran about a day and then the following day in the afternoon the Sat dropped and was no longer connected. I could get to it via the IP, and had 2 devices connected to it but it didn't show up in the Router page at all.
I had a bubble like that on the first day, then everything settled down by itself before I had a chance to restart everything. I hate networking. For me personally, it's the worst part of our computer age.
- jleecloak1Jul 17, 2017Apprentice
I don't know why that made me laugh.
- la79Jul 17, 2017Apprentice
You know with all the problems everyone is having I wish Netgear would at least acknowledge the issues. Some type of update as to what they are doing to fix the problems or when we can expect a new firmware to be released.
- tpgallJul 17, 2017Guide
I upgraded to 1.12.0.18 over the weekend. It went 3 days then I lost my internet connection twice today. It is back to the way it was where it WIFI will be up but I don't have an internet connection. I tried disabling DOS protection with no affect. Come guys, Netgear has been in the business long enough to have a better quality product than this. Is this a true Netgear product or have you licensed it from someone else? Not up to my quality expectations. Are you paying off the Orbi reviewers?
- Hydro130Jul 17, 2017Luminary
My experience so far with 12.0.18 has been great - no disconnects, and all devices are connecting well on 5ghz whenever they should (none getting stuck on 2.4), and the satellitle is picking up the devices I expect it should (versus those getting stuck on the router or something like that).
As with previous versions of the firmware, I continue to get ~120% of my provisioned internet speed everywhere in my house (and front/back yards) on 5Ghz.
The only nagging problem I was having prior to this latest firmware was disconnects on iOS wifi-calling, and those issues now seem to be resolved - no dropped calls with this latest f/w.
I manually loaded the firmware when it came out and did a factory reset as part of that update process - I do that with every major firmware release.
I'm not a Netgear fanboi or paid reviewer - I'm a happy Orbi user overall, but I'm not without some gripes too... The app is a worthless joke, and I'm diappointed that the ability to control Tx power for the 2.4 network was taken away. That needs to come back.
But for basic reliable internet coverage that just plain works, my Orbi is rockin' it these days.
- DarrellRiffeJul 17, 2017Apprentice
Yeah, I'm pretty much the same - Everything is working very well. interesting, especially in light of reading all of the comments about everything going south on this FW update for so many other users out there. I'm not going to say that the update was without headaches. For some reason, i had trouble updating the firmware on the satellites - could not get it done wirelessly, as the app just would not take the update file. I've read that one should update the satellites before updating the router, so I tried to do so several times, without success - the satellites just would not take the firmware file (I tried using the app and then tried updating by connecting to the IP addresses). So, I went against what I had read, and just had did the update through the router page - updated the router, but lost the satellites. After resetting the satellites, tried again to update through the app and then IP addresses - no dice. Finally, I decided to connect directly to the satellites with an Ethernet cable and guess what? - the satellites firmware update went through without any hassle. Still, the satellites were showing up as "connected", but not as "satellites". So, I manually reset everything (yep, a paperclip in the little hole by the power inlet, until the amber light was flashing) , and then low and behold, everything connected. Since then, everything has been working perfectly. I'll count myself as being blessed by whatever network god there is out there. As a side note, I have now enabled beam-forming and MU-MIMO. Through-put is excellent on everything, and I have about 30 devices. I'll keep my fingers crossed and hope that possibly, others may mine some sort of gem from my experience. No - I'm not an IT expert by any means, so don't try to slay me with whatever criticism. I'm just a regular guy trying to get things working in my home.
- scornwellJul 18, 2017Apprentice
Hydro130 wrote:My experience so far with 12.0.18 has been great - no disconnects, and all devices are connecting well on 5ghz whenever they should (none getting stuck on 2.4), and the satellitle is picking up the devices I expect it should (versus those getting stuck on the router or something like that).
That's great, but what is your provisioned speed?
There's no denying the firware is buggy as hell, just take a look at the broken QOS page. The Orbi may cover a couple of dead spots, but it's nowhere near as reliable as my three year old Asus RT-N66U at a fifth of the price.
- Hydro130Jul 18, 2017Luminary
scornwell wrote:
Hydro130 wrote:
....That's great, but what is your provisioned speed?
I just have 100/10 service form Comcast, and I consistently get ~120/12 . With single-unit routers I've used in the past (incl Asus 88 and 5300), that same broad level of coverage I now get at max speeds was not possbile.
I'm sorry to hear you are having issues - it's certainly not my position that frustrating connection-inhibiting issues don't exist for some people, but I am saying that those issues definitely aren't affect ALL Orbi users.
Hydro130 wrote:I just have 100/10 service form Comcast, and I consistently get ~120/12 . With single-unit routers I've used in the past (incl Asus 88 and 5300), that same broad level of coverage I now get at max speeds was not possbile.
I didn't mean to imply you were denying other's issues, just treying to get some context. If the throughput issue is a limit to 400Mbps, it's not going to affect anyone who doesn't test at that speed. You may well be having the same issue as me, but not know it.
My WiFi speed has now dropped to 30Mbps from any connected device, for seemingly no reason. The Orbi hardware seems fine and when it's working it's great, but the software is crap and we're being used as beta testers because Netgear are doing a poor job of internal testing. This is unacceptible for a premium priced router.
- DarrenMJul 19, 2017Sr. NETGEAR Moderator
If you have a RBK40 or 30 system and having issues with the latest firmware please take a look at this thread
DarrenM
- cyberprashantJul 21, 2017Luminary
I haven't had any issues with my Orbi on 1.12.0.18 RBK53 from costco (2 RBS50+RBR50) - I'm a little leary purchasing a second system for family. I wonder if there's actually more than one version of the RBK50. (I tried RBK40 recently and the amount of dropouts and restarts was insane I returned it - wonder if it was on 1.12.0.18?).
- SangwichJul 21, 2017Star
Another issue I am having besides the constant disconnect is that I can't connect to the 5Ghz band with the satellite anymore. I used to have 5Ghz turned off because I was having with the August doorbell cam but once I updated to the latest firmware and factory reset, 5Ghz is back on but I can't get on it.
