rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
ArtLee
Jul 17, 2017Apprentice
Seattleite wrote:My modem is just a modem! There's no wifi router in there....
Okay. All Orbis on same fw version? No duplicate IP addresses visible in router login? I'm really puzzled, if you have rebooted the Orbis. Now, beyond my expertise. I'll watch this thread.
Seattleite
Jul 17, 2017Guide
Yup, they're all on V1.12.0.18. It looks like there are other Orbi users with the same loss of satellites. When I get home, I'll do a manual update of the firmware just in case it was corrupted somehow....
Thanks for the tip on logging into the satellites directly!
- dpdurstJul 17, 2017Luminary
Mine ran about a day and then the following day in the afternoon the Sat dropped and was no longer connected. I could get to it via the IP, and had 2 devices connected to it but it didn't show up in the Router page at all.
Reset both router and satellite and then resync both back up and its been fine so far.
- ArtLeeJul 17, 2017Apprentice
dpdurst wrote:Mine ran about a day and then the following day in the afternoon the Sat dropped and was no longer connected. I could get to it via the IP, and had 2 devices connected to it but it didn't show up in the Router page at all.
I had a bubble like that on the first day, then everything settled down by itself before I had a chance to restart everything. I hate networking. For me personally, it's the worst part of our computer age.
- DarrenMJul 19, 2017Sr. NETGEAR Moderator
If you have a RBK40 or 30 system and having issues with the latest firmware please take a look at this thread
DarrenM
