rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Hydro130
Jul 18, 2017Luminary
My experience so far with 12.0.18 has been great - no disconnects, and all devices are connecting well on 5ghz whenever they should (none getting stuck on 2.4), and the satellitle is picking up the devices I expect it should (versus those getting stuck on the router or something like that).
As with previous versions of the firmware, I continue to get ~120% of my provisioned internet speed everywhere in my house (and front/back yards) on 5Ghz.
The only nagging problem I was having prior to this latest firmware was disconnects on iOS wifi-calling, and those issues now seem to be resolved - no dropped calls with this latest f/w.
I manually loaded the firmware when it came out and did a factory reset as part of that update process - I do that with every major firmware release.
I'm not a Netgear fanboi or paid reviewer - I'm a happy Orbi user overall, but I'm not without some gripes too... The app is a worthless joke, and I'm diappointed that the ability to control Tx power for the 2.4 network was taken away. That needs to come back.
But for basic reliable internet coverage that just plain works, my Orbi is rockin' it these days.
scornwell
Jul 18, 2017Apprentice
Hydro130 wrote:My experience so far with 12.0.18 has been great - no disconnects, and all devices are connecting well on 5ghz whenever they should (none getting stuck on 2.4), and the satellitle is picking up the devices I expect it should (versus those getting stuck on the router or something like that).
That's great, but what is your provisioned speed?
There's no denying the firware is buggy as hell, just take a look at the broken QOS page. The Orbi may cover a couple of dead spots, but it's nowhere near as reliable as my three year old Asus RT-N66U at a fifth of the price.
- Hydro130Jul 18, 2017Luminary
scornwell wrote:
Hydro130 wrote:
....That's great, but what is your provisioned speed?
I just have 100/10 service form Comcast, and I consistently get ~120/12 . With single-unit routers I've used in the past (incl Asus 88 and 5300), that same broad level of coverage I now get at max speeds was not possbile.
I'm sorry to hear you are having issues - it's certainly not my position that frustrating connection-inhibiting issues don't exist for some people, but I am saying that those issues definitely aren't affect ALL Orbi users.
- scornwellJul 18, 2017Apprentice
Hydro130 wrote:I just have 100/10 service form Comcast, and I consistently get ~120/12 . With single-unit routers I've used in the past (incl Asus 88 and 5300), that same broad level of coverage I now get at max speeds was not possbile.
I didn't mean to imply you were denying other's issues, just treying to get some context. If the throughput issue is a limit to 400Mbps, it's not going to affect anyone who doesn't test at that speed. You may well be having the same issue as me, but not know it.
My WiFi speed has now dropped to 30Mbps from any connected device, for seemingly no reason. The Orbi hardware seems fine and when it's working it's great, but the software is crap and we're being used as beta testers because Netgear are doing a poor job of internal testing. This is unacceptible for a premium priced router.
