rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
CDELL801
Jul 18, 2017Aspirant
looked around and unable to find the answer to this.. but in Firmware V1.12.0.18 the radio power is now missing, does that means its now on auto? locked to what i had set it to? 100%? anyone have any ideas?
captain_phaser
Jul 18, 2017Apprentice
CDELL801 wrote:looked around and unable to find the answer to this.. but in Firmware V1.12.0.18 the radio power is now missing, does that means its now on auto? locked to what i had set it to? 100%? anyone have any ideas?
The ability to set the power levels for both bands has indeed been removed. The reasoning has yet to be stated by Netgear. See my earlier post for other issues that need to be addressed:
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/m-p/1325589#M10542
If you'd like to rollback firmware without auto-updating, download the previous firmware files for the router and satellite, then add a domain block for downloads.netgear.com and save to your config. Then proceed to do a manual update.
- scornwellJul 18, 2017Apprentice
captain_phaser wrote:If you'd like to rollback firmware without auto-updating, download the previous firmware files for the router and satellite, then add a domain block for downloads.netgear.com and save to your config. Then proceed to do a manual update.
From my experience, once you've manually rolled back the firmware it won't auto-update.
- KGrueJul 19, 2017Guide
I am still getting disconnects on my iPad 10.5 Pro, same as I had on previous firmwares on my old iPad Air 2.
They are only for a few seconds but enough to notice!
So, for me v1.12.0.18 hasn't improved matters at all.
- StkasmJul 19, 2017Apprentice
KGrue wrote:I am still getting disconnects on my iPad 10.5 Pro, same as I had on previous firmwares on my old iPad Air 2.
Are you sure it's not roaming? We have three iOS devices of different generations - iPad air, iPad Air 2 and iPhone 6s, they do not have any problems working with wifi. Nothing changed after 1.2.0.18 update
- la79Jul 19, 2017Apprentice
So you aded that block, downgraded and no issues with it AutoUpdating it again? If so I'm going to try this tonight when I get home.
- esiebert7625Jul 19, 2017Star
Mine finally auto updated after about 5-6 of manualling updating. There goes Netgear's support claim that if you manually update it won't auto update again. Once again after this auto update to 1.12.0.18 constant disconnects. I immediately downgraded both devices again to 1.11.0.20 and then followed the steps on page 5 of this thread using telnet to set NVRAM settings to hopefully prevent it from auto updating ever again. I did note that one of the NVRAM settings is different on mine from what was in the instructiions. I think it was the orbi_auto_upgrade one which was actually listed as orbi_auto_upg when I listed the settings with the nvram show command.
- cyberprashantJul 22, 2017LuminaryBlocking downloads.netgear.com wasnt enough i still got updated. Gonna try telnet method
- JohnyboyJul 23, 2017Guide
Had stable beta firmware (1.11.0.20) for a month and then Orbi and satellite auto updated three days ago and now disconnects resurfaced. I performed a factory reset hoping i coud downgrade back to beta firmware however it defaulted back to newest firmware. Blows my mind that Netgear has not resolved this and even worse ive never in my life seen a puece of hardware auto update to the newest firmware automatically!! Netgear you should be ashamed! Have had this Orbi system for four months now and have had nothing but issues with it. Wish i could return it but im stuck with it. Will never purchase another Netgear product again as this has been nothing but a major headache fir me and my family for months now!
