rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Seattleite
Jul 19, 2017Guide
Looking at https://www.netgear.com/support/download/ V1.12.0.18 no longer appears - does that mean it's been officially pulled?
- captain_phaserJul 19, 2017Apprentice
Seattleite wrote:Looking at https://www.netgear.com/support/download/ V1.12.0.18 no longer appears - does that mean it's been officially pulled?
Still available here:
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
- SeattleiteJul 19, 2017Guide
V1.12 was uploaded on 7/11 - any guesses as to when V1.13.xx.xx will be released - hopefully bringing my satellites back into the fold?
- Hydro130Jul 19, 2017Luminary
It was not pulled for 50 - it was just pulled for 30 and 40... I would think that any corresponding concerns would affect the 50 too, but the Netgear gods seem to disagree.
I'm one of the lucky folks who is having no issues with latest f/w on my 50, but I'm still curious to see how this all unfolds.
- scornwellJul 19, 2017Apprentice
Good catch, looks like you could be right. Some official word from Netgear would be nice though. There's been pretty much nothing but radio silence since this release dropped.
They really need to start doing two things:
- Start engaging with their customers here and
- Start putting some real effort into the software for these products. It's plainly obvious they've dedicated very little resource to this.
I wish I could dump this thing and start looking at alternatives, but I can't unload this router on anyone else in good faith.
- esiebert7625Jul 19, 2017Star
I don't think it was ever on that downloads page, I'll always found it here and it hasn't disappeared:
https://www.netgear.com/support/product/RBK50#download
- st_shawJul 19, 2017Master
scornwell wrote:
...Some official word from Netgear would be nice though. There's been pretty much nothing but radio silence since this release dropped.Look at the sticky post at the very top of this forum entitled "Orbi - Wireless Network not available or LED flashing white on Router or Satellite"
- Tigerman4LSUJul 19, 2017Star
How hard is it to downgrade? I am tired of MacBook Pro switching to the 2.4 GHz from the GHz network. I would like to turn off the 2.4 GHz radio.
I would also like them to add a feature where you can say this MAC address can only connect to this radio.
I am not impressed with their test team. The conversations I have had with them they said they only had two Macs for their testing.
George
