rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
 This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public.  Hope it helps!
 Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
 - Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
 - Fixes the Dropcam disconnection issue.
 - Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
 - Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
 - Fixes the issue where the Orbi app can’t display more than 20 connected devices.
 - Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
 - Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
 - Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
 - Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
st_shaw
Jul 19, 2017Master
scornwell wrote:
...Some official word from Netgear would be nice though. There's been pretty much nothing but radio silence since this release dropped.
Look at the sticky post at the very top of this forum entitled "Orbi - Wireless Network not available or LED flashing white on Router or Satellite"
Tigerman4LSU
Jul 19, 2017Star
How hard is it to downgrade? I am tired of MacBook Pro switching to the 2.4 GHz from the GHz network. I would like to turn off the 2.4 GHz radio.
I would also like them to add a feature where you can say this MAC address can only connect to this radio.
I am not impressed with their test team. The conversations I have had with them they said they only had two Macs for their testing.
George
- scornwellJul 19, 2017Apprentice
Tigerman4LSU wrote:How hard is it to downgrade? I am tired of MacBook Pro switching to the 2.4 GHz from the GHz network. I would like to turn off the
Easy. Just download the firmware you want and use the manual update feature. Do your sattelite first to be on the safe side, though I had no issues with downgrading the router first. Once you've been downgraded the firmware will no longer auto-update, though you will get a notification.
 - esiebert7625Jul 19, 2017Star
It will auto update, see my post 163, mine took 5 days though before it did. Use the telnet method to edit nvram settings or set a block rule to downloads.netgear.com to stop it
- jleecloak1Jul 19, 2017Apprentice
esiebert7625 wrote:It will auto update, see my post 163, mine took 5 days though before it did. Use the telnet method to edit nvram settings or set a block rule to downloads.netgear.com to stop it
You shouldn't have to go through all of that just to keep your router from upgrading to a firmware you do not want. You risk bricking your router. Netgear should have this set to not auto update by default or at least give you more control in the UI menu.
Well that blows. Thanks for the tip, I'll be blocking the update service when I get home.
