rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
ChuckP
Jul 21, 2017Aspirant
Went to create a thread and noticed this beast...
Just purchased the RBK50 set. Router seems to work fine and the satellite works great when first paired, but as soon as the satellite gets powered cycled it no longer works properly until the whole system is factory reset. The strange thing is, that the satellite's ring does show it is connected (solid blue ring) and detects when it drops connection from the router (pulsing magenta ring), however if you plug into the satellite it doesn't assign IPs, and the Orbi status page shows no connected satellite.
Anyone having sucess downgrading the firmware? If so, does it just auto-update and break itself again?
- SangwichJul 21, 2017Star
Don't really mean to sound like an ass but I'm just speaking as a software engineer. Why do you force updates when you guys release updates without proper testing? I see you guys are trying to make it convenient for people that lacks knowledge but this is a pretty attractive hardware on paper that attracts other type of users.
I'm starting to think my 5Ghz band is still off even with the factory reset. Now I have to deal with downgrading just to turn it back on. I can't connect to 5Ghz even when I'm right in front of the satellite and the router. None of my devices are connected to 5Ghz.
- captain_phaserJul 21, 2017Apprentice
ChuckP wrote:Went to create a thread and noticed this beast...
I've been on 1.11.0.20 with no auto-updates yet. The simplest thing to do is to add a domain block to downloads.netgear.com in Advanced > Security > Block Sites. Set Keyword Blocking to Always and apply the setting as soon as you've manually updated. If you're comfortable with telnet, there's a guide on page 5 of this thread to also manually set the config auto update variables. I have both of these steps in place, but I think the first step should be sufficient.
