rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
mkenny28
Jul 24, 2017Apprentice
I have a ton of devices on my network and they all seem to be function as they are supposed to EXCEPT for my Sprint S8 Plus. After the firmware update my S8 Plus drops off of my network for 20-30 seconds at a time (with an exclamation point next to WiFi icon) before it reconnects. This happens 100% of the time when I move between router/satellites. Internet appears to be fine but then a page or app will stop loading. Only way to get back on the internet is to wait or toggle WiFi (but toggling will often result in another disconnect). A bunch of other S8 users over on the Samsung forums are having the same exact issue with Orbi.
MacrossMike
Might as well ask this here...
I've got a RBR/RBS50 setup, and 1.12.0.18 is somehow still automatically downloading itself and installing to my router and satellites even though I went in and disabled automatic updating in the NVRAM.
Does anyone have an alternative way to shut off automatic updating? I kind of need my system functional, and 1.12.0.18 cripples my system so badly that none of my satellites work as access points, and my WiFi speeds drop by at least 50%.
