rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
sunnyyan
Jul 24, 2017Initiate
I have the 3 pack Orbi AC3000 from Costco. Several connection drops per day before and after the latest firmware V1.12.018. I thought it was my Comcast service issue for a few weeks then I missed the return deadline to Costco. Now, I'm stuck with a $500 system worse than wireless routers I had less than 1/3 of cost. I'm tired and fed up by this and false sense of hope the next firmware will solve this issue.
captain_phaser
Jul 24, 2017Apprentice
sunnyyan wrote:I have the 3 pack Orbi AC3000 from Costco. Several connection drops per day before and after the latest firmware V1.12.018. I thought it was my Comcast service issue for a few weeks then I missed the return deadline to Costco. Now, I'm stuck with a $500 system worse than wireless routers I had less than 1/3 of cost. I'm tired and fed up by this and false sense of hope the next firmware will solve this issue.
Costco is usually very generous with their return policy. I'm sure if you explained what is going on with your device they would accept the return for you.
