rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
MacrossMike
Jul 26, 2017Apprentice
Well, I've officially given up...
After reverting to v1.11.0.20 manually and disabling updates in the NVRAM, I've suddenly started getting random disconnects on most of my WiFi devices that I wasn't getting before the release of v1.12.0.18 and the rollback. I was going to give Netgear until month's end to straighten this mess out, but the competition just made me a much better offer. Gonna audition the Linksys Velop and D-Link Covr as replacements this weekend.
JMU1998
Jul 26, 2017Luminary
MacrossMike if Netgear does not plan to add the option to adjust radios I am going to look elsewhere also sadly because I did like Orbi but Netgear is determined to handicap it, please do post comparison of Velope performance and stability experience.
- ArtLeeJul 26, 2017Apprentice
JMU1998 wrote:MacrossMike if Netgear does not plan to add the option to adjust radios I am going to look elsewhere also sadly because I did like Orbi but Netgear is determined to handicap it, please do post comparison of Velope performance and stability experience.
Can you explain why you want to adjust radios? I just have a plain Orbi router/satellite system and have no deep knowledge of wifi and don't know if I -should- be able to adjust transmitter power or why.
- MacrossMikeJul 26, 2017Apprentice
With respect to why you'd want to adjust radios... there are a few reasons. Mostly it has to do with reducing co-channel interference in areas where there are several WiFi APs operating in close proximity to each other. Being able to command your router to stick to certain channels, and/or modifying transmit power can do a lot to improve service quality in apartment buildings and unseparated condos, or homes where there are multiple WiFi APs operating for different things.
(For instance, I have three separate wireless networks in my home. One is heavily firewalled and meant for IoT devices, one is for the home security system, and one is for everyday use.)
I'll certainly share my evaluations of the Linksys Velop and D-Link COVR-3902 mesh network systems once they arrive. I'm expecting the Velop this Friday, and the COVR sometime next week.
MacrossMike wrote:
With respect to why you'd want to adjust radios... there are a few reasons. Mostly it has to do with reducing co-channel interference in areas where there are several WiFi APs operating in close proximity to each other. Being able to command your router to stick to certain channels, and/or modifying transmit power can do a lot to improve service quality in apartment buildings and unseparated condos, or homes where there are multiple WiFi APs operating for different things.(For instance, I have three separate wireless networks in my home. One is heavily firewalled and meant for IoT devices, one is for the home security system, and one is for everyday use.)
Thanks. I'm in a single home, but I can see at least a half-dozen networks around, but then don't appear to interfere with me.
Question: Would I gain anything by turning off 2.4ghz? Not that it's possible with the current fw. I do have b/g/n devices, like printers. Can they connect to 5 ghz? Or, do they require 2.4?
- JMU1998Jul 26, 2017Luminary
ArtLee yes good question, it really boils down to your needs, requirements and your surrounding environment. Speaking for my scenario not having the option to adjust the radio power is detetremental to my environment where there is considerable amount of interference already. people have the misconception the most powerful wireless router is the best not true, if everybody in your neighborhood gets the most powerful wireless router without adjusting the radio to stay within the confines of your home or area where you need wifi then just blasting at full strength down 5 houses each direction does not server any purpose and does not help anyone including yourself just polluting and adding to interference.
I am very disappointed Netgear took away the ability to adjust radio power as my scenario does not require 2.4GHz all my devices use 5Ghz and distance and speeds are more than adequate for me so I want the ability to turn off or ar a min be able to reduce the non used radio power down to 25% like I used to be able to as a common courtesy to those around me.
most neighbours are now doing this if there scenario allows it we started this neighborhood wide effort to get everyone to adjust the power on their radios to fit their needs, some have done it some can't depending on individual need.
netgear with latest firmware have taken away the ability to adjust radio power to be the is a step back not forward, very myopic vision of Firmware capability.
Until I started watching this forum I had no idea you could adjust power level or even turn off transmitters. I think most of my neighbors know very little about computers, much less about wifi. I seem to be the neighborhood cosultant on iPads and laptops. And I obviously don't know what I don't know!
