rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
MacrossMike
Jul 27, 2017Apprentice
Well, I am officially 100% done with my Orbi RBK-50 as of today.
I got sick of dealing with the frequent unwanted automatic updates and all the problems v1.12.0.18 was causing with non-functional Orbi satellites, curtailed WiFi speeds, and high processor usage and started to audition replacements. The Orbi was a contender on the older v.1.11.0.20 firmware, but on v1.12.0.18 both the Linksys Velop and D-Link Covr knock it into a cocked hat. The Velop may have reduced maximum WiFi speed because it doesn't have a dedicated backhaul, but it's a hell of a lot more stable right out of the box. D-Link's Covr makes a mockery of the Orbi by being every bit as fast as a properly-functioning Orbi RBK-50, but with none of the stability problems, a better-designed user interface, and day one support for ethernet backhaul.
Needless to say, I will be retiring my Orbi system in favor of the D-Link Covr. Maybe once Netgear gets the firmware straightened out I'll fob it off on one of my brothers when they need a wireless setup or something. It cost too much to simply throw out.
