rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Seattleite
Jul 27, 2017Guide
For those who have downgraded (and changed nvram settings to prevent the auto-update) - what firmware did you settle on? it seems like a lot of people are reverting to 1.11.0.20, but I was wondering if one of the even earlier ones might be better? (I have an RBK53, i.e., the Costco router + 2 satellites, and neither satellite is connecting as a satellite)
Cheers
cyberprashant
Jul 28, 2017Luminary
@eattleite wrote:For those who have downgraded (and changed nvram settings to prevent the auto-update) - what firmware did you settle on? it seems like a lot of people are reverting to 1.11.0.20, but I was wondering if one of the even earlier ones might be better? (I have an RBK53, i.e., the Costco router + 2 satellites, and neither satellite is connecting as a satellite)
Cheers
Costco RBK 53 here - 2 sets in our family - both rock stable on 1.11.0.20 downgrade. (also Mu-MIMO and beamforming off by default and not sure if you need to do but disabled 20/40 co-existence under advanced wifi settings).
