rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
rexet
Aug 02, 2017Guide
All you had to do is reset both router and satellites to get things back to normal?
I will try this as soon as I am home.
Rergarding thanking Netgear support team... if it is that simple why don't they come here to explain the procedure if it could help many users?
ChuckP
Aug 02, 2017Aspirant
So just to confirm the fix is to upgrade to 12 then go into the settings and reset the configuration to default then proceeded to power cycle all units? Do you have to reset the backhaul password or does the full configuration reset do so?
- mkenny28Aug 02, 2017Apprentice
ChuckP wrote:
So just to confirm the fix is to upgrade to 12 then go into the settings and reset the configuration to default then proceeded to power cycle all units? Do you have to reset the backhaul password or does the full configuration reset do so?Personally I did not reset the backhaul password but the config reset may have done that. Not sure.
