rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
CaptStevo
Aug 03, 2017Star
For those that have tried to block downloads.netgear.com and have seen their Orbi auto-update again (like me), I have included some other domains to block that seem to have stopped them on my unit. They are the top 10 domains my satelite has tried to contact, in order, from most to least contacted. Adding them to my main router's blacklist appears to have made the firmware update server unreachable.
- www.netgear.com
- updates1.netgear.com
- ftp.updates1.netgear.com.edgesuite.net
- 472263.ftp.download.akadns.net
- A1599ER83NVYL8.iot.us-west-2.amazonaws.com
- http.fw.updates1.netgear.com
- http.fw.updates1.netgear.com.edgekey.net
- e70.g.akamaiedge.net
I will report back if blocking these domains has stopped the auto-upgrade madness. I had previously blocked downloads.netgear.com and set the appropriate nvram options, and still had my unit upgrade itself after a few days. Hope this helps!
