rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Retired_Member
Jul 11, 20171.12.0.18 is as solid as 1.12.0.16 for me, and my problems with the 1.11.x versions remain fixed for me. No disconnects, all sats showing in the web UI, 90+ devices. Nice work Netgear!
cyberprashant
Aug 04, 2017Luminary
MacrossMike and others having the router auto-upgrade issues despite telnet block: See my tips on Page 12 of this thread and as well the original telnet post on page 5. What may be different in my setup is that I'm in AP mode AND I have a DD-WRT netgear wndr4300 ahead of the orbi that is running Access restriction --> WAN --> Access restriction for : downloads.netgear.com --> not sure if the the dd-wrt router is preventing upgrades but I'm well over 10 days with no auto-upgrading occuring. If you're able to have another router ahead of the orbi and put the Orbi in AP mode and still perform the telnet block, perhaps that is the trick whereas others are reporting it keeps auto-updating despite all attempts to downgrade permanently.
So in my setup : Cable modem --> Border router running DD-wrt --> ORBI
- RogerSCAug 05, 2017Virtuoso
cyberprashant wrote:MacrossMike and others having the router auto-upgrade issues despite telnet block: See my tips on Page 12 of this thread and as well the original telnet post on page 5. What may be different in my setup is that I'm in AP mode AND I have a DD-WRT netgear wndr4300 ahead of the orbi that is running Access restriction --> WAN --> Access restriction for : downloads.netgear.com --> not sure if the the dd-wrt router is preventing upgrades but I'm well over 10 days with no auto-upgrading occuring. If you're able to have another router ahead of the orbi and put the Orbi in AP mode and still perform the telnet block, perhaps that is the trick whereas others are reporting it keeps auto-updating despite all attempts to downgrade permanently.
Well, have I just had some strange stuff happening...decided to try AP mode, using another Netgear router with the wireless turned off as my main, wired-only router, to see if I could get 2.4GHz. wireless turned off on the Orbi without worrying about auto-update. And I put in the restriction for the "download" domain mentioned above on the main router, to see if that would help the Orbi to not auto-update. The Orbi was on the latest at that point, so I figured I would set it up in AP mode and then flash the previous firmware. Not a smart move...I got it working fine in AP mode, and then it fell apart before I could flash the Orbi back to the previous firmware. It appeared that the satellite was still in contact with the router, but the router was showing magenta. After a few minutes, they were both showing magenta. I could log into the satellite for a while, but not the router, so the router was basically isolated. Not a great situation, totally nonfunctional...so went to Plan B. This was the first problem that I've had with the latest firmware, AP mode not working properly, and it made the Orbi unusable.
Plan B: Reset the Orbi router and satellite, and got them up in router mode. Reloaded my saved settings, that worked fine. At that point, I flashed the previous firmware, and again went to AP mode once everything stabilized. The router and saltellite are even now working fine with the previous firmware release in AP mode. However, I found that one can't turn off 2.4GHz. wireless on the Orbi in AP mode, the Advanced Wireless settings screen would not display, don't know if that's typical for an AP or not...So I flipped the Orbi back to router mode and turned off the 2.4GHz. wireless in router mode. Then back to AP mode, where the "Advanced Status" still showed the 2.4GHz. wireless turned off. And it's working fine as an AP.
Okay, now the bottom line. Even though the Orbi's "Advanced Status" shows that the 2.4GHz. wireless is off in AP mode, Wi-Fi Analyzer on my clients shows that the Orbi's 2.4GHz. wireless is on. Not only is it on, but it's using 40MHz. channel width, taking over half of the 2.4GHz. band. So, for all the time that I've spent on this, about half a day in total, lots of times waiting for the Orbi to come up after each thing I've had to do to it, I've accomplished absolutely nothing. Other than to verify that the latest firmware doesn't work in AP mode for me. And that I can't turn off 2.4GHz. wireless on the Orbi no matter what I do.
I can also tell that it's only a matter of time before this thing will auto-update, since it has the purple "a new firmware upgrade is available, click here to get it" thing on the "Advanced Status" page. If the Orbi can see that firmware, it'll apply it when it's darn good and ready :-). Pretty sure of that.
So I'm going back to regular router mode and wait for the auto-update that's coming. I should start a pool to guess when it'll auto-update.
Not happy. Hoping that Netgear pulls their firmware together so that this thing is more usable.
Ah, my Orbi is still in AP mode, but for some reason the Advanced Wireless settings screen does display now. It shows the 2.4GHz. radio disabled, even though the radio itself is not disabled. I did an "Apply", just to see if the Orbi could figure out that I was asking to disable the radio, and no effect, 2.4GHz. wireless still on. So I turned the 2.4GHz. radio back on, hit "Apply", and turned it off and clicked "Apply" again. No effect.
Again, don't know if this is typical for an AP, but this works properly in router mode. That is, with the previous firmware on the Orbi you could turn off the 2.4GHz. wireless in router mode and it actually went off :-).
- st_shawAug 06, 2017Master
RogerSC The most recent firmware (1.12.0.18) removed the ability to turn off 2.4 GHz and adjust power levels. Also, the Orbi ALWAYS has an active hidden SSID on 2.4 GHz (on the same channel) even when 2.4 GHz is turned off. Lastly, if you select the 20/40 MHz coexistence setting, then Orbi will fallback to 20 MHz if it detects another AP with overlapping channels.
