rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
JMU1998
Aug 09, 2017Luminary
I do not understand why everyone "has" to have the same Firmware??? SERIOUSLY does every human "has" to wear the same shoe?? Everyone's environments are different everybody has different scenarios everyone's networking needs are different, people have specific requirements for their situation for their networks...along with forcing the pollution and unnecessary interference by not allowing radio power adjustment or turning off radio not needed as per individual needs and requirements... these are very basic networking concepts being flagrantly ignored by the experts at Engineering is baffling!! Can someone explain why we are now being forced to blast radio at full strength in all directions introducing and contributing to interference already in our neighborhood is this considered smart? I have no way to adjust power on radios any more this is smart? Sorry just running out of patience with Netgear after a year of optimistically waiting... Things with Firmware are regressing instead of forward progress.
scornwell
Aug 09, 2017Apprentice
JMU1998 It makes support cheaper and easier and means Netgear can push out imprtant fixes with some confidence that they'll actually get applied. It's not a bad idea in itself, but there needs to be an option to opt out.
- DarrellRiffeAug 09, 2017Apprentice
Speaking of updates ... 1.12.0.20 was released for the Orbi AC2200 systems. Nothing listed beyond 1.12.0.18 for the AC3000 systems. Hmmmm ...
- ArtLeeAug 09, 2017Apprentice
DarrellRiffe wrote:Speaking of updates ... 1.12.0.20 was released for the Orbi AC2200 systems. Nothing listed beyond 1.12.0.18 for the AC3000 systems. Hmmmm ...
It hasn't hit my Orbis yet. Mine should update automatically.
- YabbadabbaDooooAug 10, 2017Apprentice
Anyone have any ideas of how I can dig out of the mess the newest FW 1.12.0.20 caused my RB40 system? I spent 2 hours on it last night trying to roll back the FW to 1.11.0.20. The internet disconnects were so frequent I would end up having to start over in the GUI. I did a full Erase from the GUI, I did a Factory Reset....loaded 1.11.0.20 and it auto updated back to the lastest Crapware. I literally am having to use the hotspot on my phone to work since the wifi disappears several times an hour, loses internet connection and has about 1/4 the speed I was getting before.
Are there some settings I am not thinking of that I should set a certain way? I have tried changing channels (even used a Network Analyzer), turned off Guest Network, toggled Beamforming off and on, did multiple power up resets. Nothing is working and I can't seem to get back to a clean load of 1.11.0.20. This is nuts. Any help would be appreciated. I am kicking myself for not returning this when I had the chance. $300 paperweight.
- scornwellAug 12, 2017Apprentice
I'm just going to keep posting this until one of you actually answers.
@DarrenM or @ChristineT
I think the general consensus here is that we don't feel like we're being listened to and the response is totally inadequate, so who can we escalate this to?Willfully ignoring this issue is only making it worse. It's been a month already FFS.
- madbrainAug 09, 2017Luminary
scornwell wrote:JMU1998 It makes support cheaper and easier and means Netgear can push out imprtant fixes with some confidence that they'll actually get applied. It's not a bad idea in itself, but there needs to be an option to opt out.
On the other hand, releasing firmware updates full of regressions is going to raise their support costs significantly. Judging by the duration of the support queue, a lot of people are rightly complaining.
