rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
rhester72
Aug 14, 2017Virtuoso
@TXGunLover wrote:Each gap represents the Orbi RBK50 & two sats going nuts and rebooting for a few minutes. During that period, the WAN is unreacable and devices can't connect to the WIFI. 1.12.0.18...
What's the target IP for your ping test? I'd like to do the same.
Rodney
Retired_Member
Aug 14, 2017Rodney,
It's my public IP address.
- rhester72Aug 14, 2017Virtuoso
@TXGunLover wrote:Rodney,
Does it sit on your network? i.e. are you accessing it via NAT loopback or is it being tested from outside your local network? (I just set one up to test www.google.com over IPv4 and IPv6.)
Rodney
- Retired_MemberAug 14, 2017
- RogerSCAug 14, 2017Virtuoso
What I've gathered from reading this thread and my own experience is that v1.11 is broken for some, and v1.12 is broken for others. For me, v1.11 and v1.12 are both fine in router mode, but v1.11 is broken in AP mode. V1.12 is working well for me in AP mode, aside from the functionality that Netgear has removed (like disabling 2.4GHz. wireless and being able to disable auto-update for the firmware if needed). This makes it virtually impossible to go back to a previous version and have a stable router, since the Orbi will just auto-update itself for most people.
So a situation has been created where if the latest firmware doesn't work for you, then you're pretty much out of business. It would be helpful if Netgear would give out some useful information like what domains to block to prevent the Orbi from finding new firmware on it's own, and settings (using telnet) that will prevent the firmware from auto-updating. But to this point, they've avoided giving out any work-arounds, as far as I've seen.
The time has passed for Netgear to expect it's customers to just wait for the next firmware. It's time for Netgear to give out the information needed for users to work around these problems. While this isn't a Netgear support forum, it's a user peer-to-peer forum, Netgear clearly monitors this forum, and needs to help it's users. If they don't feel that they should help their users just because they need help, then they should help because having all these public postings can't be good for Netgear's business. If I had read this thread before getting an Orbi, I'm pretty sure I would have found a different solution for my router needs. This has gone on way too long.
- IDGuy42Aug 14, 2017Guide
I'm using the RBK50 system, V1.12.0.18 in router mode and have constant disconnects from multiple devices on my network. I've had to hardwire in some primary devices to get some stability. I wasn't able to get my iPhone to get an internet connection for most of the day yesterday, turning on/off wifi, rebooting, etc, even though it showed as connected to wifi. Android phones have slow speeds and then often drop internet connections and sometimes regains it at the same location after some time. Google Home constantly disconnects and doesn't recover requiring a reboot. The list goes on.
I tried downgrading to the previous version and ended up having to spend two hours on support to reset my Orbi system since satellites wouldn't stay connected. I personally don't care about the features which were removed in the latest version, I just want/need a stable wifi connection for my devices.
IDGuy42 wrote:I personally don't care about the features which were removed in the latest version, I just want/need a stable wifi connection for my devices.
I think we all agree this is priority #1.
- dazzywazzyAug 14, 2017Star
I just purchased the Orbi RBK50 and found these forums.
Before setting everything up, I downgraded the firmware on both router and satellite.I then used https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5 to stop the auto update from happening.
Everything is runnning fine for me. My auto update settings were slightly different than the post above and after commiting the NVRAM and performing a reboot, one of the settings when back to enabled. I then set it to disabled for a 2nd time, commited the NVRAM and rebooted 10+ times and it's been running perfect for a few nights now.
- bwherryAug 14, 2017Star
Thanks dazzywazzy, that's good to know. I'll have to re-check the NVRAM settings after doing some reboots to make sure the auto-update stays off.
- madbrainAug 14, 2017Luminary
dazzywazzy wrote:Everything is runnning fine for me. My auto update settings were slightly different than the post above and after commiting the NVRAM and performing a reboot, one of the settings when back to enabled. I then set it to disabled for a 2nd time, commited the NVRAM and rebooted 10+ times and it's been running perfect for a few nights now.
A few nights is not really long enough. Tell us when it's been more than a week without an update.
Sure thing.
I've been monitoring a few times a day.
FWIW my NVRAM settings which I changed are belowRouter:
orbi_auto_upgrade=0
orbi_auto_upg=0
auto_update=0
auto_check_for_upgrade=0
auto_upgrade_flag=0
fwupgrade_Method=MANUAL
Satellite:
auto_upgrade_flag=0
Settings I'm monitoring but haven't changed as I don't know the outcome
Router:
detect_update=899798033
manual_upgrade=109908109666630
green_download_upgrade_stat=0
upgrade_satellite_image=109908109666630Satellite:
upg_status=1
upgrade_check=49902240
Thanks dazzywazzy! That's plenty more settings than I changed - and I didn't change any settings on the satellite since I didn't know that was necessary. I'll give those a shot and see what happens... (or _doesn't_ happen, as I'll hope) :)
- cyberprashantAug 17, 2017Luminary
root@# nvram show | grep auto_*
vpn_access_mode=auto
wl_auto_antenna=1
set_auto_agreement=0
orbi_auto_upgrade=2649318224781159
ipv6_autoConfig_dns_assign=0
auto_upgrade_flag=0
ipv6_autoConfig_dns1=
ipv6_autoConfig_dns2=
upnp_enable_autoScan=0
ipv6_auto_dns_assign=0
orbi_auto_upg=0
bas_auto_conn_flag=0
autofw_port0=
ipv6_auto_dns1=
ipv6_auto_dns2=
qos_auto_bandwidth=0
green_enable_autorefresh_status=0
enable_dev_auto_refresh=1
wl_rate=auto
auto_update=0
auto_check_for_upgrade=0Mine has been stable for several weeks on 1.11.0.20 (only difference here is Orbi is in AP mode with a R7000 ahead of it with downloads.netgear.com blocked - perhaps thats it).
- dazzywazzyAug 17, 2017Star
Mine has been stable for a week now.
Router mode, no websites blocked. NVRAM config I did was posted previously. Hopefully it can help some users.
