rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Pichontech
Aug 14, 2017Tutor
There are so many firmware versions available for Orbi since it came out that it is ashame the auto update feature kills the option to choose what works for your system. In the perfect world, every firmware update should be an improvement but clearly it is not the case for Orbi. I know some people figured a way for the auto update to stop working but we should not be spending 3 hours with reboots and googling a way to do it... I don't buy that because some dude here mention a lawsuit Netgear cannot communicate in this thread anymore. The ratings for this product everywhere went from 4.7 stars to 4.2 and keep going down because of this lack of customer service. I sure hope this company is not charging customers for wasting their time with a rep after the three month "free" support. Not to justify Orbi but other mesh wifi systems are plagued with issues as well. Difference is that their customer service responds and make people feel that they are heard and things will get better. It's been almost a month since the last update. I hope the new firmware comes soon and definitely turns the auto update off. We can then at least pick which firmware works best for our situation...
