rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
alberts
Aug 18, 2017Star
Working with a support call on a Orbi System router + 3 sattelites because of constant wifi signal dropouts. After numerous resets and many times emails back and forth with support i summarize: 1.12.0.18 seems not to be ready for prime time for a lot of people who spent a lot of money.
some people here are already happy if the systems works for a few days with out issues., i would not call that a reliable stable technology at all.
no ETA's for new firmware. maybe one day they will fix it, till then hardly to be recommended.
Lucky those people where it works, great signal strength , great penetrations through difficult walls, but stability sucks ..
Anonymous
Aug 18, 2017I was one of those users that had rock solid performance until the 1.11.x release. Not sure what happened, but it's been a mess since then.
- gbjacksonAug 18, 2017Apprentice
Just out of curiousity, since 1.12 remains broken for lots of folks and 1.11 seems to have a nasty habit of regularly dropping iOS devices, what are others' thoughts on rolling farther back? Is there any sort of consensus on what the last stable version of the system's firmware was?
- AnonymousAug 18, 2017
gbjackson wrote:Just out of curiousity, since 1.12 remains broken for lots of folks and 1.11 seems to have a nasty habit of regularly dropping iOS devices, what are others' thoughts on rolling farther back? Is there any sort of consensus on what the last stable version of the system's firmware was?
For me, 1.10.x was rock solid for my 90+ devices as were all releases prior to that. Interestingly 1.12 seemed to have fixed that for me for about a period of 3 weeks, UNTIL I rebooted the orbi and the sats and then began experiencing the reboots and "Internet Not Available" in Android and Windows. Note, I have no iOS devices.
- scornwellAug 18, 2017Apprentice
It seems Netgear have started censoring posts here. My last post was deleted without notice.
So they refuse to answer questions and delete posts that call them out. That's the kind of company we're dealing with.
- bwherryAug 18, 2017Star
I went back to V1.9.1.12 per dazzywazzy's recommendation, and my satellite has stayed connected ever since (4-5 days now, no auto firmware updates yet due to settings changes I made via nvram) - /me knocks on wood.
My wife and I did notice that our Internet speed did seem pretty slow the past couple days, though - roughly 1/4 the speed it usually is (~24Mbps down instead of ~100Mbps down). I power cycled the Orbi router this morning and the speed went back to normal. I've yet to check if the satellite has become disconnected, if the auto firmware update settings have magically changed or if the firmware has gone and updated itself, though. /me crosses his fingers
Brian
