rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
gbjackson
Aug 19, 2017Apprentice
Thanks. Since mine auto-disabled itself yet again (seems to be Friday night/Saturday morning thing here), I'll roll back to 1.10 and see how it goes.
I've gotten a couple of "we're still working on it" e-mails from support after sending them all of the logs, screenshots, etc..., they have asked for, but that's about it.
cohoman
Aug 19, 2017Star
I've been having the same disconnect issues with the latest firmware (V1.12.0.18). It seems the WiFi is connected to my Android smartphone and tablet, but the internet is not available. My wife reported to me she's been having the same issue with her iPhone as well. Very frustrating. I tried to downgradt to V1.9.1.12, but I can't seem to get the main router to accept the firmware (the web page just spins and spins and doesn't finish). I'm at the point now of ditching this system and going back to a conventional single-Router system (not Netgear!).
- YabbadabbaDooooAug 19, 2017Apprentice
cohoman wrote:I've been having the same disconnect issues with the latest firmware (V1.12.0.18). It seems the WiFi is connected to my Android smartphone and tablet, but the internet is not available. My wife reported to me she's been having the same issue with her iPhone as well. Very frustrating. I tried to downgradt to V1.9.1.12, but I can't seem to get the main router to accept the firmware (the web page just spins and spins and doesn't finish). I'm at the point now of ditching this system and going back to a conventional single-Router system (not Netgear!).
Try a Factory Reset and try to load the FW of the Satellite(s) first. May have to plug in directly to them with Ethernet. Even if you get the system to take a rollback without a factory reset, in my experience something still doesn't work right unless you do a clean load.
Also, if you can return the system for a full refund you will be better off than those of us who missed our window of opportunity. Even if you get it stable and working as it is supposed to, it is a crapshoot whether the next FW update jams up your system.
- cohomanAug 19, 2017Star
Thanks for the advice. I bought this router system from Costco, so I do have the ability to return it for a full refund. I originally decided to go with this system because the back half of my house has a weak connection to my WiFi router. I've tried everything, but there's something in the walls that seems to block the signal between the front and back of the house. The Orbi system seems to work well so far as signal strength, but the constant internet disconnects is very frustrating. I'm leaning towards returning the system and going back to a single router. I may need to find a way to hardwire two routers together to get better coverage between both halves of my house.
Cohoman.. I have a similar house. One story, spread out with the main service plug in (modem and router) in one corner of the house. Fireplace and walls between that and Master bedroom in opposite corner of the house. I was using a Netgear R6100 and an extender but the speed was horrible from both. I have 125Mbs Down cable internet so I needed something like the Orbi. When it was working as advertised for about 3 weeks, it was the best I had ever seen. Sadly as you know that doesn't last. If I were you, I would run a 100ft Cat 5 cable from your modem (may need to buy an Ethernet Port Switch) to the part of your house that a single router won't reach. Then you can plug in another single router there and possibly just run it on 5Ghz if you don't need broader coverage. That is what I think I am going to do as soon as it cools off enough to go through my attic. It isn't as hard as it sounds. You are fortunate to have bought your system from Costco. I have heard from others on this Forum that they have the best return policy of anyone.
In the meantime, after a factor reset and clean load, followed by at least one power cycle, try changing the 2.4 and 5 Ghz channels, turn off anything not really necessary like Beamforming, MI-MUMO, etc.. and see what happens. You may also want to try changing MTU size to 1500. I read that was a solution NG Tech Support finally came up with for a user in another thread.
Good luck.
- cohomanAug 20, 2017Star
I can telnet into the main router (192.168.1.1) to change the nvram settings so it will not auto update the firmware, but how do I do that for the satellite units? I tried to telnet to their IP addresses, but I get a "cannot connect to remote host. connection refused".
Thanks.
- dazzywazzyAug 20, 2017Star
Did you go to the IP/debug.htm and enable telnet on the satellite first?
