rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
bwherry
Aug 20, 2017Star
So I _thought_ things were good w/ V1.9.1.12, but I discovered a few problems:
1. None of our Macs could properly connect to the wifi. They would always get a "self-assigned" IP of 269.something and not be able to access the Internet (despite being "connected" to the wifi). Some kind of DHCP issue it seems.
2. Our Apple TV couldn't connect to the Internet - same problem with 269.* IP address as the Macs.
3. The speed would start okay (around 115 Mbps down) but deteriorate over the course of a few hours - down to like 40 Mbps.
After discovering these problems, I tried the 1.10.whatever and 1.11.something firmware versions too, but the problems remained.
Despite its terrible flaw of dropping satellite connection, the V1.12.0.18 firmware fixes all of these issues. Of course! Ugh. My satellite is located in a detached home office and the three wired computers I have in there depend on it for their Internet. So my current options are to have good wifi speed, wifi to the Macs and a working Apple TV (on the latest firmware) or a connected satellite (on the older firmware). Sigh.
Maybe I'll try the factory reset thing on V1.12.0.18 and just hope to not lose power.
This really sucks. I was looking at the Linksys Velop but in all the reviews I found they say the Orbi is better. C'mon Netgear, get this fixed already!!
Brian
Brian
scornwell
Aug 21, 2017Apprentice
bwherry I'd be wary of looking at Amazon reviews:
http://fakespot.com/product/netgear-orbi-high-performance-ac3000-tri-band-wifi-system-rbk50
By comparison:
http://fakespot.com/product/google-wifi-system-set-of-3-router-replacement-for-whole-home-coverage
- RogerSCAug 21, 2017Virtuoso
You don't have to look at Amazon reviews, you can look at the tech reviews on the internet for the Orbi and Google WiFi. As to "fakespot", I haven't found it helpful. I don't really know what sort of algorithms they use, but as far as I've experienced, they aren't much good. Maybe they'll get better, or maybe I don't look at the sort of products where it would be helpful, but they've been wrong most of the time that I looked at their results. Gave up on them after a few tries.
