rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
nxc
Aug 21, 2017Apprentice
So, I seem to have fixed my issues on the latest firmware (1.12). After going back and forth a number of times and playing with various NVRAM settings, I decided to start from scratch. Here's exactly what I did:
- Enable telnet and sign into the router.
- nvram erase
- nvram commit
- reboot
Items 2-4 above are commands to enter into the console. Once it's rebooted, sign into the admin panel and then restore firmware defaults.
After doing this, running latest firmware, my WiFi and wired speeds are super fast. I'm getting over 900Mbps wired on Speedtest, and my iPhone 7 Plus is regularly exceeding 300Mbps down and goes over 400Mbps up.
I strongly suspect that corrupt NVRAM settings are the source of these problems. Whether it's bad defaults or perhaps corruption when upgrading, the end result is pain. I also think the QoS implementation is the main source of the problem. As others have noted, re-running the Speed Test seems to help things, but I think the key to a working 1.12 installation is to NEVER RUN THE SPEED TEST. The instant you run it the router saves the results and the problems set in. If you reset to defaults and never touch the speedtest settings you may find it improves things.
As always, YMMV. Hope this helps somebody.
- nxcAug 21, 2017Apprentice
gbjackson wrote:nxc To clarify, which particular sort of problems were you having?
I had a variety of issues. At least once a day the satellite would disconnect. I’d see it flashing the light for a bit as it fixed itself. Sometimes it needed a manual reboot to reconnect. In general, I was seeing very slow wireless and wired speeds. WiFi speeds would top out around 60-70 Mbps. Wired would reach around double that. After reflashing and testing a variety of things it seems to be to be squarely a problem with QoS settings. Regardless of what I tried, once I ran a Speedtest, problems started. Even messing with the Speedtest results in NVRAM wouldn’t fix it. Obviously I’ll need to watch and see what happens, but everything is flying fast and reliably now.
- RogerSCAug 21, 2017Virtuoso
One advantage to using the Orbi as an AP is that when you do a factory reset or clear nvram to get a fresh start, there's little configuration to be done. So I have less temptation to restore a saved configuraton file that might itself be corrupt. I agree that simply flashing a router time after time without ever resetting and renewing one's configuration settings is an invitation to problems. While I don't see the need to do this for every flash, especially since Netgear doesn't say that it's required, it is good to do this when problems come up. If only to verify that problems are really firmware problems as opposed to accumulated nvram corruption problems. No router is immune to those.
- nxcAug 25, 2017Apprentice
nxc wrote:So, I seem to have fixed my issues on the latest firmware (1.12). After going back and forth a number of times and playing with various NVRAM settings, I decided to start from scratch. Here's exactly what I did:
- nvram erase
- nvram commit
- reboot
So it's been five days, and everything has been rock solid. Again, your mileage may vary, but updating to v1.12, wiping NVRAM settings via telnet and subsequently performing a factory reset, and never using the built-in Speedtest seems to have fixed my issues. My satellite doesn't appear to have dropped connections, the satellite is currently handling about 1/3 of the devices on my network, and my speed test results (from the website -- NOT THE ADMIN) are fantastic:
This is approaching the effective limit of what you can expect from a modern iOS device. I'm very happy with the results. Orbi is finally living up to its reviewer reputation.
- scornwellAug 25, 2017Apprentice
- nvram erase
- nvram commit
- reboot
Well what do you know, this seems to have worked for me too. NVRAM reset, follow by factory reset. Reconfigured everything manually and it's working fine so far. Before I could only get 70-80Mbps wired to the router, now I'm gettting 800Mbps+. I'll do some testing later to see if I can narrow the cause of the issue down, starting with the speed test which has some broken QOS settings hidden behind it.
- martyfpAug 25, 2017LuminaryI agree with the theory about the speed test impacting QoS.
- jcalex22Aug 26, 2017Star
Well, it has been six weeks since I disconnected my Orbi system waiting for a new firmware update, but after reading this latest text:
nvram erase
nvram commit
rebootI decided to give it a try and so far, so good with the latest firmware release, following these instructions.
Thanks to all for providing this information. It has made a difference and now use my Orbi and wait for the next offical v.2.0 release!
Cheers!
