rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
alberts
Aug 21, 2017Star
Netgear support offers to replace my satelittes. I have three and dont know which of them is "Defect"
Has anybody went through such a replace action with the problem of disconnects solved ?
II'am not sure all the effort of replacing the satelittes does any good if the firmware is the big issue (what it clearly seems to be)
Will be interesting in Germany we have 2 years warranty by law, not just 90 days ...
Albert
bwherry
Aug 21, 2017Star
scornwell I was referring to tech reviews on places like Tom's Guide, etc. - not Amazon reviews. I'll take them all with a grain of salt, but still, the Orbi does seem to be the better hardware - especially for my needs, where having the built-in 4-port ethernet switch on the satellite is really nice.
For others, like alberts wondering about hardware replacements, I've been there, done that. Before I discovered that the V1.12.0.18 firmware was problematic, I just figured there was something wrong with my satellite (since we still had wifi w/ good performance from the router). So I purchased a new satellite. Didn't help - I could never get that new satellite to sync with the router. So, "The router must be the problem," I thought. So I then purchased a brand new RBK50 system (consisting of the RBR50 router and one RBS50 satellite). That worked fine for a few days, then the satellite stopped syncing, just like before. Ugh! At this point I searched more and found this thread - so I plugged in my old router/satellite, did the factory resets and downgraded the firmware. And lo and behold, the satellite started syncing again. (but there were other problems with the older firmware, which I discovered later - see my previous posts)
HTH,
Brian
