rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
madbrain
Aug 21, 2017Luminary
So, I got my replacement RBR50 router today, since the previous one was bricked during a failed firmware rollback.
I'm running it all on the latest firmware and giving it another try and see how long it takes for the satellites to drop off.
I have set the main SSID to OrbiSucks . I chose a password that does not include spaces, or any other weird characters. Then I disabled SSID broadcast.
I setup the SSID that all my devices are already setup for as "Guest network", with its weird SSID name and secure passphrase, spaces and all.
I moved my Canon Pro 100 printer back to one of the ports on Orbi satellite #1 instead of the powerline ethernet.
I got a bunch of PINGs going from one of my local single board computers (Odroid XU4) to the Orbi router (setup as AP), each of the 2 satellites, the printer which hangs off one satellite, and my 2 electric car chargers. Let's see how long this will all last... Previous experience previously with 1.2.0.18 were mostly about 48-72 hours until one or both satellites dropped.
gbjackson
Aug 21, 2017Apprentice
Netgear support sent me a beta firmware version earlier today (labeled 2.0.0.62-debug). Installed it, and after a recommended factory reset and some initial weirdness, the satellite and router are talking, with the satellite showing up on the browser interface as a connected satellite, not just a connected device. Logging into the satellite's IP shows that the radios are enabled, and that there are devices connected. Watching now for drops with connected iDevices, as that was also a problem. I haven't dug into the beta to see what else is different, other than noticing that the "attached devices" screen shows a little more information than the 1.12 version did.
Crossing my fingers and toes, knocking wood, and everything else I can think of. I love the system when it works, and hoping that this new version restores functionality.
- madbrainAug 21, 2017Luminary
gbjackson wrote:Netgear support sent me a beta firmware version earlier today (labeled 2.0.0.62-debug). Installed it, and after a recommended factory reset and some initial weirdness, the satellite and router are talking, with the satellite showing up on the browser interface as a connected satellite, not just a connected device. Logging into the satellite's IP shows that the radios are enabled, and that there are devices connected. Watching now for drops with connected iDevices, as that was also a problem. I haven't dug into the beta to see what else is different, other than noticing that the "attached devices" screen shows a little more information than the 1.12 version did.
Does this beta add the ability to stop automatic firmware updates ?
- Killou92Aug 22, 2017Tutor
How is the beta firmware? can you share it somewhere?
Thanks
- NobodyHereAug 22, 2017Initiate
I opened a support ticket this past Saturday due to satellites disappearing and many of the other issues reported here. The tech escalated to level 2 support, and they told him they are aware of the issues and will be releasing a firmware update this week. I told them I was returning this to Costco in a week if they didn't. He was adamant that a fix was imminent. I see there is one person here with beta firmware, so that is encouraging.
I'm sure they don't care if I return it, but the response changed gave a sliver of light.
- JMU1998Aug 22, 2017Luminary
gbjackson did this new Beta Firmware bring back the ability to adjust radio power or turn off radio?
- gbjacksonAug 22, 2017Apprentice
Don't know - haven't dug into it to that extent, and not entirely sure where I'd look for that particular capability.
24 hours in, router and satellite are talking, no drops watching Hulu, other streaming apps on iPad.
Don't see anything allowing any greater control over firmware updating.
- BeiBarAug 22, 2017InitiateWhere can we get this beta software? Could you upload it to Dropbox or another sharing platform?
- Dustin278Aug 23, 2017Apprentice
What else can you comment on this BETA Firmware? Do you own a Samsung S8/S8+ and if so did that resolve the connection issues? I have emailed my Level 2 support guy to request this same firmware. Thanks
