rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
bwherry
Aug 21, 2017Star
chuncomunco I'm interested to hear more about your experience with the Linksys Velop... When you say "It's not as the Orbi" do you mean that the wifi signal isn't as strong or doesn't reach as far? Or something else?
I fear I may have to give the Linksys Velop a try as well...
Brian
chuncomunco
Aug 22, 2017Initiate
Sure.
The thing I noticed with the Linksys Velop is that it loses speed and distance significantly when it has to penetrate the signal through thick walls. My house is a mid 60's Ranch and has quite a few walls that have concrete filled sections.
With the Orbi, it was powerful enough to penetrate the walls in my house and still provide excellent speed and distance.
I hope that beta testing goes well, if official firmware is released with positive results, i'll consider switching back.
