rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Alexsolution
Aug 25, 2017Initiate
With this last firmware I can't set portforwarding and DMZ zone. I try everything but don't work!
The other future work perfectly for me, I have a lot of device connected and I need to reboot the network only once a month.
Question: If I do a factory reset, I lost the connection between RBR50 and satellite, or only configuration parameter are rest?
- RogerSCAug 25, 2017Virtuoso
Alexsolution wrote:With this last firmware I can't set portforwarding and DMZ zone. I try everything but don't work!
Yes, you will lose the connection between the router and satellite(s) when you factory reset them, as well as setting the configuration settings back to factory defaults. You'll find that you need to start reconfiguring from the very beginning, like when you first got the Orbi. This includes bringing up the router and satellite(s), and waiting until the router finds and gets in contact with the satellite(s). It isn't difficult, the router firmware guides you through the whole process, but it does take a few minutes. For this part, I find it is very handy to have the desktop that I'm using for configuring and admin'ing the router directly plugged into a LAN port on the router (I use the Orbi in AP mode).
