rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Dustin278
Aug 28, 2017Apprentice
nxc wrote:Running the Speedtest appears to set a few internal values that are used to sit limits for up and downstream bandwidth. The speedtest doesn't seem to be very reliable in terms of choosing the best partner ISP, and will often produce a test result that is significantly below what your connection is capable of. Never running the Speedtest appears to prevent some switches from being flipped, which more or less means the router treats all content equally and shuffles it along as fast as possible.
There are a number of hidden settings and magic variables in these routers, and there's more than ample evidence for some really sloppy coding practices.
Eek! If we have run the speed test is there an easy way to reset this?
nxc
Dustin278 wrote:Eek! If we have run the speed test is there an easy way to reset this?
If you are not having any issues then I would suggest leaving things as they are. If you are having issues, I would suggest trying the instructions I posted a few pages back regarding erasing NVRAM settings and manually restoring default firmware settings. After that you can reconfigure everything to taste, but avoid the Speedtest or modifying any QoS settings.
- n4choAug 28, 2017Apprentice
OK - I may take this plunge. I have a ton of IP reservations set by MAC addresses - is there any way to impor those without reconfiguring everything manually? Thats the main reason I havent taken this step. Like some 60+ reservations tied to port forwarding.
- nxcAug 28, 2017Apprentice
Wish I had better news, but I'm unaware of a way to back those up on their own.
