rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
DarrellRiffe
Aug 29, 2017Apprentice
What just happened? Out of nowhere, my Orbi RBK53 shut everything down, and rebooted to initial state, showing my only router as Orbi28 (NOT my system SSID, passwords etc.). At first, I thought that it must have been an auto-firmware update. But no- once up , it is the same ole 12...18 update that shows up. This, after going through the complete setup again. Now, I'm getting drops out the Wazoo (whereas I wasn't before with 12....18), even though I set everything to the original SSID and password. What the hell is going on? I'm about to take a sledgehammer to this system and replace it with ... well, anything would be an improvement . Same firmware version that was tolerable before , but now things have gone to hell . Very unhappy at the moment. Thanks to AT&T cellular, I can post this. Without, I'd be dead in the water.
Retired_Member
Aug 29, 2017
I am sorry this happened to you, but this is EXACTLY what happened to me. After the disaster that was 1.11.x, I tested 1.12.16 and then upgraded to 1.12.18. For almost two weeks it was perfect, then, while replacing UPS's on the two sats and the router, I of course had to power them off and back on. Since powering back on. 1.12.18 has been a disaster, exactly as you describe. Something is flaky in this firmware, because from 1.10.x backwards everything was stable.
