rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Screamz
Aug 29, 2017Guide
I've had my Orbi for about a week now. Everything seems fine, except the internet speed in backyard is really bad (20ft from orbi router). Both my wifes iphone & mine show full signal strength, but the internet speed seems up and down. Once second it's fast, one second it's slow. On the iPad it seems alittle better, but still not quite the speed i'm getting inside the house. Really upset about this, I really should of done some more research before purchasing this damn thing.
I have tried downgrading to 1.11.0.2 but it seems the same. Please netgear release a fix for this ASAP. Or i'm gonna have to try to sell this system and get my $500 back. Really upsetting.
- Dustin278Aug 29, 2017Apprentice
I am beyond frustrated and have wrote reviews on Amazon and Costco for people to stay away from this product - It is unstable and unusable for the past month. Support is slow and non-helpful.
- rexetAug 29, 2017Guide
Sames here. I'm gonna write a review on Amazon and major reseller here in France warning people to stay away from this product.
