rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
DarrellRiffe
Aug 29, 2017Apprentice
Sevo123 wrote:Hi everyone. I asked on facebook netgear support about when will they fix the issue about the orbi not being fully mesh system where the satalites will connect to eachother and tak to eachother instead of only to the wifi. Also I asked about all the firmware issues going on with this1.12.10.18 they replied like this.
Hello Sevak,
Thank you for reaching out. Sorry for the delay. Our engineering is working on a firmware to be released to support this.
Best Regards,
NETGEAR Team
I asked when this will be no response yet. I will update you guys if I get anything back.
he
As for me, even if the update came tomorrow, it wouldn't be soon enough. I can't believe that my system functioned just fine when I bought it and even after the V1.12.0.18. Then, a couple of nights ago -- Boom -- everything resets to ground zero and it hasn't held a connection for longer than a few minutes at a time since - no matter what I do. I can't believe that I'm reinstalling my old Airport Extreme tonight.
scornwell
DarrellRiffe wrote:As for me, even if the update came tomorrow, it wouldn't be soon enough. I can't believe that my system functioned just fine when I bought it and even after the V1.12.0.18. Then, a couple of nights ago -- Boom -- everything resets to ground zero and it hasn't held a connection for longer than a few minutes at a time since - no matter what I do. I can't believe that I'm reinstalling my old Airport Extreme tonight.
Try backing up your settings and doing a NVRAM reset, followed by a factory reset and reconfigure/restore settings. Then don't reboot or run QoS.
- RogerSCAug 29, 2017Virtuoso
I feel that I should emphasize not restoring saved settings from just before you did the reset. Restoring settings from a saved configuration file made just before the reset would restore your QoS settings, and any other settings that might have somehow become corrupted. Instead one should manually re-enter one's settings to get a clean start. Or if you had a saved settings file made just after doing a reset and manually re-entering settings (except for running the QoS speed test, of course), that should be clean, and you could use that.
- DarrellRiffeAug 29, 2017Apprentice
Try backing up your settings and doing a NVRAM reset, followed by a factory reset and reconfigure/restore settings. Then don't reboot or run QoS.I have
I have done all of that. Telnet NVRAM reset/commit, factory reset, etc. Following that, I was diligent in never running the QOS speedtest. It seemed to work well for a few days. Then everything went haywire when it rebooted on its own. The router SSID defaulted to "Orbi28" and and forced me through setup as if it were just out of the box. What seems to have stabilized things for now (and I'm keeping my fingers crossed on this) is that I unplugged both satellites, and started the router back up. Seems stable, but it has only been a couple of hours.
- Dustin278Aug 30, 2017Apprentice
ALL of my problems finally solved after recieving the latest firmware update last night from Level 2 support - V2.0.0.64. I went from V2.0.0.62-debug to V2.0.0.64..
No more S8 problems - I think this was after the new Verizon update yesterday
No more satellite disconects
Reliable speeds even 120' into my backyard
Cross your fingers but I think the release should be anyday now!
- ScreamzAug 30, 2017Guide
How do we get our hands on this firmware??
I have no patience going through netgears support lol.
