rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
gbjackson
Aug 30, 2017Apprentice
alberts wrote:
Do i understand it: when you boot the new beta firmware the mess is back?
Nobody has said this. I'm running a beta firmware and can hit "reboot" tonight to see what happens.
Dustin278
I have rebooted many of times without problems with the Beta firmware and newest V2.0.0.64.. Running flawlessly for past 24 hours with latest Verizon update for my S8 and V2.0.0.64
- Mlny2Aug 30, 2017InitiateWas working from home today and my wifi was dropping every 20 mins or so. I got in touch with tech support and he had me do a hard reset. It seem to help but I doubt it. He did say new firmware will be out next month but didn't say specific day.
- jleecloak1Aug 30, 2017Apprentice
next month........
- scornwellAug 30, 2017Apprentice
My understanding is it's a couple of weeks away, so sometime in September seems likely, but don't quote me on that.
- RogerSCAug 30, 2017Virtuoso
jleecloak1 wrote:next month........
is only a couple of days away *smile*.
- scornwellAug 31, 2017Apprentice
It'll still be next month 30 days from now.
- RogerSCAug 31, 2017Virtuoso
Guess my glass is half full and yours is half empty *smile*.
My glass is full of Scotch.
- Dustin278Aug 31, 2017ApprenticeIf you look hard enough from a post this am someone posted one of the newest firmwares that is probably in beta: https://community.netgear.com/t5/Orbi/Updated-to-V1-12-0-18-now-Satellite-will-not-sync-quot-Wireless/td-p/1321830/page/2
Dustin278 wrote:
If you look hard enough from a post this am someone posted one of the newest firmwares that is probably in beta: https://community.netgear.com/t5/Orbi/Updated-to-V1-12-0-18-now-Satellite-will-not-sync-quot-Wireless/td-p/1321830/page/2Still there...
Same one I got last night from level 2 support and fixed my problems..
- DarrellRiffeAug 31, 2017Apprentice
Dustin278 wrote:Same one I got last night from level 2 support and fixed my problems..
So ... what model of Orbi system do you have? I have the RBK53 (RBR50 router and two RBS50 satellites), and I so want to try this. Right now, I'm keeping things limping along by just running the router with no satellites - not exactly what I paid for. But I'm reluctant to try the firmware without knowing what Orbi systems it has successfully fixed.
It's for RBR50 and RBS50.
I also have the RBK53 - make sure you update the satellites first and then the router! There are multiple ways to update but here is the way I did it.
1)Find ip address for each satellite and login - one of mine was 192.168.1.5 and the other was 192.168.1.3 - yours will be different I am sure but those were mine - then I loaded the RBS50 for the satellites then it took about 3 minutes each to finish
2)updated the router via 192.168.1.1 and used the file RBR50
- Mlny2Aug 31, 2017InitiateGot disconnected again so guess what? I'm hooking up Google wifi for now and then try again when net gear gets their act together.
- PhysicalEdAug 31, 2017Star
Maybe they're actually testing it this time?
- rexetAug 31, 2017Guide
Thank you for the link to the v2 beta firmware. I have updated both the router and the satelites this morning. Let's see how they behave now.
- jleecloak1Aug 31, 2017Apprentice
Did you get disconnected using the beta firmware?
jleecloak1 wrote:Did you get disconnected using the beta firmware?
I have been up and running for almost 48 hours with no problems - My S8 was disconnecting but after the latest Verizon update is running perfect
- nxcAug 31, 2017Apprentice
rexet wrote:Thank you for the link to the v2 beta firmware. I have updated both the router and the satelites this morning. Let's see how they behave now.
Despite having a rock solid v1.12 installation, I went against protocol and went ahead and installed the beta. I immediately ran into issues. Downstream bandwidth dropped from 900+ Mbps to 100.
Based on prior experience, I immediately enabled telnet, did the NVRAM wipe, and then did a factory reset and proceeded to reconfigure everything, yet again. Now everything is working fine, just like before.
I don't know what Netgear's engineers are smoking, but it sure looks like the upgrade process is broken. So unhappy right now. Even though my network is working fine, I now can effectively assume that every update I want to install just to get security fixes is going to involve a full wipe and reconfigure.
NETGEAR: GET YOUR ACT TOGETHER!! 😡😡😡
Hmmm...I replied to this posting already, my reply seems to have disappeared. So I'll try again *smile*.
Sometimes when a router is flashed, memory corruption can result. What the user sees is problematic behavior, and if they were to get in touch with Netgear support, one of the first things that's suggested is to reset to factory defaults, and re-enter the user's configuration. It is common practice with consumer routers that if problems arise after a firmware update flash, manual or automatic, that the router is reset and reconfigured. While Netgear would like this not to happen, I'm sure, it really does happen and there's not much that Netgear can do about it. Kind of a random occurance for the level of hardware that consumers are willing and able to pay for.
So your experience, while not fun, is part of the normal course of long term hardware use. I really hope that your router will be fine from here on out, but I've had to reset my Orbi units here once or twice as well due to problematic behavior, and that's just life. Most times when I do a factory default reset, it's because that's the most expedient way to fix a serious problem. And things are usually good for quite a while after that. I really hope that's the case for you.
- MarkC1024Aug 31, 2017Luminary
I've been solid on 1.12.0.18 as well, and also decided to try the beta. Working fine without any speed loss (200 down). I do make it a point that once the router and satellites are up on the new firmware, take everything down and then bring them back up starting with the router. Haven't had to do a reset or nvram wipe - yet.
RogerSC wrote:Hmmm...I replied to this posting already, my reply seems to have disappeared. So I'll try again *smile*.
In most instances I'd agree with you. But having used many brands of router, and many routers period, including Netgear routers, I can confidently say this is the most trouble I've ever had with a router product. My previous Asus router didn't have any issues beyond not quite covering my home. The D-Link that preceded it was great for the couple years I had it. The Linksys before that was decent, too. None of them had the major stability issues that the Orbi seems to have. Even DD-WRT was more stable during the years I ran it.
Dunno. I just have higher expectations from a $400 product. I'm more or less happy with it, despite my complaints, because when it works it is faster and smoother than anything I've used before. That doesn't mean Netgear gets a free pass for releasing a buggy product, or for its complete silence publicly about the issues the hardware faces.
There is no reason for memory to become "corrupted" during a software update, nor is there any reason for settings to get broken or changed, beyond poor programming practices and/or quality assurance. If changes are big enough that old settings are incompatible then the update should reset settings, not just leave the router half-working The reason we continue to see this so much in consumer routers is the bar has already been set pretty damn low, and we've come to accept that it's normal.
To be clear, the issue nxc is having happens every single time you upgrade to 1.2 or 2.X from an earlier version. It's a defect in the update process that should be obvious if they were testing correctly and it's an issue that I raised with them well over a month ago. It also requires a NVRAM reset, not just a factory reset to resolve.
- spinkickSep 01, 2017ApprenticeCan you guys point me to the nvram reset process? Also do we need to reset the nvram on the satellites?
