rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Dustin278
Aug 30, 2017Apprentice
If you look hard enough from a post this am someone posted one of the newest firmwares that is probably in beta: https://community.netgear.com/t5/Orbi/Updated-to-V1-12-0-18-now-Satellite-will-not-sync-quot-Wireless/td-p/1321830/page/2
Dustin278
Same one I got last night from level 2 support and fixed my problems..
- DarrellRiffeAug 30, 2017Apprentice
Dustin278 wrote:Same one I got last night from level 2 support and fixed my problems..
So ... what model of Orbi system do you have? I have the RBK53 (RBR50 router and two RBS50 satellites), and I so want to try this. Right now, I'm keeping things limping along by just running the router with no satellites - not exactly what I paid for. But I'm reluctant to try the firmware without knowing what Orbi systems it has successfully fixed.
- scornwellAug 30, 2017Apprentice
It's for RBR50 and RBS50.
- Dustin278Aug 30, 2017Apprentice
I also have the RBK53 - make sure you update the satellites first and then the router! There are multiple ways to update but here is the way I did it.
1)Find ip address for each satellite and login - one of mine was 192.168.1.5 and the other was 192.168.1.3 - yours will be different I am sure but those were mine - then I loaded the RBS50 for the satellites then it took about 3 minutes each to finish
2)updated the router via 192.168.1.1 and used the file RBR50
- Mlny2Aug 31, 2017InitiateGot disconnected again so guess what? I'm hooking up Google wifi for now and then try again when net gear gets their act together.
- jleecloak1Aug 31, 2017Apprentice
Did you get disconnected using the beta firmware?
- Dustin278Aug 31, 2017Apprentice
jleecloak1 wrote:Did you get disconnected using the beta firmware?
I have been up and running for almost 48 hours with no problems - My S8 was disconnecting but after the latest Verizon update is running perfect
