rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
alberts
Sep 01, 2017Star
Thank You guys for providing the link to get the newest firmware. Something support was not able to do since it came out.
Many of us sufferred beyond imagination from the bad implemantation of this product. So hopes were high that the recent sotware 2.x somewhat solves the always changing signal levels (and drops) of the satilites.
So far this is not the case, even with this firmware the orbis are not ready for primetime
For some people the firmware have solved some problems, for other's like me still not. And then beware to reboot and nobody knows what happens then.
To be fair, so far the firmware is only beta. Maybe at some point in the future netgear with their desastrous support and development manages to make their expensive product fly. I look elsewere. I have scruples to sell the 4 unites knwing that they are crap.
After 4 weeks i give up wasting time ...
jleecloak1
Sep 01, 2017Apprentice
I'm with you on this. I haven't even installed the beta firmware after getting a copy of it from a link that was posted earlier because I have been disappointed so many times with past updates. I give up and I will post my Orbi on Ebay. I can't believe that we have to suffer at the cost of losing $400 for a broken product and no chance of a refund.
This just reaffirms my case I said months ago that the problem isn't the firmware it's the hardware. In order to get the product stabilized they are going to have to disable so many features and functions that you are going to be left with a severely over priced router + access point and not a even close to what you paid for.
- mahughesnhSep 01, 2017Guide
I really feel awful about all the problems you folks have had. I wasn't very bright and didn't start reading the posts on here until after I ordered my Orbi. Then sat in fear of what would happen after I installed it. Then it updated to the 1.12.0.18 firmware and the fear started all over again.
I am 3 weeks into using the Orbi and it has not even burped. It has been rock solid and my coverage is much improved from my old router.
Every day when I get home from work, the first thing I do is check to see if the wifi is still on. Always on, and according to the stats it has run continuosly except for when it rebooted itself after installing the firmware update.
This is the first Netgear router I have had that has lived up to it's billing. So far that is! I still have that nagging doubt that something will happen. I can only hope that the future firmware updates don't change that.
- ArtLeeSep 01, 2017Apprentice
I, too, check my Orbi system every day. It has been solid. But, I keep thinking it will fall over completely. I feel for all of you with so many different problems. If I start getting those issues, I don't know what I'd do. I'd be tempted to move back to my slower Airport Extreme/Express combination.
- spinkickSep 01, 2017ApprenticeI am also rock stable with good speeds. My satellites both are stable and I max out my 350 mb internet connection on a wired laptop to a satelite. After the Samsung update, my phone has had no connection issues. I run the orbi in access point mode, however. I have two neighbors but they are k seperate channels and my 5ghz channel is completely away from any kind of interferance outside the orbi radios. Wish I could help
