rhester72
Jul 11, 2017Virtuoso
Firmware V1.12.0.18 Discussion
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4...
- Jul 11, 2017
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
Pichontech
Sep 01, 2017Tutor
3rd day on the beta firmware 0 drops everything working fast and finally fine... If it continues like this I'll never update again and will stay with this beta firmware for the rest of my Orbi days lol don't trust new firmware anymore specially if you cannot prevent auto updates. Crazy how long Netgear is taking to release the new firmware but happy to be stable with the beta.
spinkick
Sep 01, 2017Apprentice
I have this sneaking feeling they are waiting on chipset manufacturers for the radios in these things to release updates that they then build into the firmware. All these companies do is take the new chipset tech and package it into a product.
- Bing-StrollerSep 01, 2017Luminary
Well, if they are releasing the Orbi Pro at least we know what Netgear are focused on !
Much the same as last time when the RBK30 and RBK40 were released - all efforts were focused on their release to the detriment of the old RBK50.
